New Cruiser Project
New Cruiser Project
Hi all:
I'm a relative noob at putting wrenches to bikes, but over the last few years I've been able to learn a few things and not mess things up too terribly.
Found this Huffy Classic Beach Edition for free, so this is now my spring time project.
It's a 1x6, everything seems to be there and relatively intact.
The grip shifter is toast, grips are worthless, a fender screws for is missing, a fender stay is a little bent, brake calipers and levers all need some TLC.
The rest seems mostly cosmetic.
The plan is to replace the few parts needed, clean, lube, adjust, etc. and have a new bike for, well - just because.
So all in all, a pretty reasonable pick up for a 10 minute detour while out doing other errands.
Any info about age, things to look out for, etc. greatly appreciated.
Thanks!
Thanks!
Likes For Cmichini:
Bikes: There is always room for one more.
Quoted: 184 Post(s)
Liked 388 Times
That's a great catch for free! Enjoy the process of refreshing it and keep us posted with your progress.
Don
Don
It didn't take me long to get this project done, here's a recap and some photos:
Before
Bike seemed complete, and really just in need of some TLC and a few fixes.
Grip shifter was toast.
Caliper brakes were complete but needed some help (my first set of caliper brakes - so good learning)
One missing fender screw.
Everything else seemed to be intact, but just grimy/stiff.
During
I took it down to the bare frame & rear derailleur (didn't seem to need to be removed - and I didn't want to expand too far outside the comfort zone) & cleaned all the parts/surfaces.
Greased bearings in the headset, axles, and bottom bracket (my first BB work).
Cleaned up all the chrome as best I could with aluminum foil.
Installed New inner tubes, new brake pads, replaced shifter
Front caliper brake spring was misshapen so it wouldn't engage the studs - I reshaped it for now.
Future
It's been out for a cruise a couple of times, and the brakes work but I think I may need to go look for springs or replacements at my local recyclery.
All in all, lots of learning, had a great time and got a fun bike for about $30 in parts.
More pix coming in follow up posts.
Before
During
Future
Some more before Pix
Before right side
Drive train/chain guard
headset, front fender/brakes
Rear fender/brakes
Before right side
Rear fender/brakes
Some after pictures:
left side
right side
Headset, front fender/brake
bottom bracket
left side
right side
bottom bracket
Likes For Cmichini:
Quoted: 880 Post(s)
Liked 817 Times
Nice job; you're cruising in style now. Tektro makes a caliper brake for about $20 that might be a slight improvement. The long flexible arms are a deterrent to power.
Thanks for the tip on some new brakes.
I think any replacements won’t need to be too robust as this will be for casual in-style cruising.
