Giant Cadex seatpost pin/binder size question
Old 05-24-22, 02:13 PM
v8powerage
v8powerage's Avatar
Bikes: Giant Cadex 980C
Quoted: 77 Post(s)
Liked 9 Times in 3 Posts
What size does Giant Cadex 980C etc (road bike) use, I can't undo mine I know it's 30mm length but I don't know if it's M6 or M8, can't undo it and I had one snap before so I'd rather have spare before applying more force on it.
v8powerage is offline
Old 05-24-22, 03:01 PM
bamboobike4
Quoted: 359 Post(s)
Liked 582 Times in 336 Posts
Define "can't undo" first.
Mine was M5, so I'm not sure what you have going on there.
If it's an issue with a mangled socket, try SAE sizes for a better fit?
Sometimes, the SAE can come in between an M5 and M6, generally on a reamed M5.
bamboobike4 is offline
Old 05-24-22, 03:10 PM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
M5 are You sure? I'm not talking about hex socket size but the bolt diameter. It's seized I feel it might snap had that before on other bike.
Old 05-25-22, 09:05 AM
bamboobike4
Quoted: 359 Post(s)
You didn't clarify either in your post.
Is the bolt seized with the sleeve, or is the assembly seized in the binder?
I've seen the bolt/sleeve seized, but turning in the binder.
I've seen the bolt seized in the binder by itself, with the sleeve able to be taken off on the L side.
Without knowing, can't really address.
Pics would help; you may have to post 10 times to get that feature.
Good luck, and let us know.
Old 05-25-22, 09:54 AM
Mackers
Quoted: 194 Post(s)
Liked 180 Times in 141 Posts
Man's been a member for far longer than you, though less loquacious.
Mackers is offline
Likes For Mackers:
Old 05-25-22, 01:05 PM
bamboobike4
Quoted: 359 Post(s)
Then a pic would help.
How's that, since you've offered no help?
At least I'm trying to understand the issue and assist.
More than I can say for you, or was that too loquacious?
I can shorten that to two words.....
Old 05-25-22, 06:37 PM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
I'm asking for the diameter inside I did post picture of the bolt don't know which to chose I see M6 and M8 for sale they both have 5mm hex socket.
Old 05-26-22, 03:19 AM
Mackers
Quoted: 194 Post(s)
It's as standard a binder as you can possibly imagine.
M5 bolt, thread is 5.85mm.
Mackers is offline
Old 05-26-22, 08:35 AM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
I don't think this is a standard bolt, I can only find M6 and they come in different lengths hard to tell what length mine is by measuring thru frame I think it's measured before the bolt heads.
Old 05-26-22, 09:57 AM
bamboobike4
Quoted: 359 Post(s)
I can pull mine out and measure it, if you'd like.
Old 05-26-22, 10:25 AM
Mackers
Quoted: 194 Post(s)
That was what's in mine, looks exactly like what it says on it
Male part is 21.5mm, female 13.5, shoulder on both is 2.6mm.
26mm exactly fully threaded.
Mackers is offline
Old 05-26-22, 10:29 AM
bamboobike4
Quoted: 359 Post(s)
The narrowest is 26mm fully inserted. How wide will it go?
Old 05-26-22, 03:42 PM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
Well if it's M5 then they don't sell those anymore only M6.
Old 05-26-22, 11:15 PM
Mackers
Quoted: 194 Post(s)
I don't think it matters.
As long as the female part is <8mm wide and the male part doesn't bottom out before properly tensioned any binder will do.
I just tried Sugino, Campagnolo and Procraft and all fit the same and all appear to work for my Cadex.
Mackers is offline
Old 05-30-22, 05:20 PM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
So I don't know what size do I need 19mm then I guess because they measure it on the inside, sugino are really expensive must find cheaper.
Old 05-31-22, 05:14 PM
v8powerage
v8powerage's Avatar
Quoted: 77 Post(s)
I managed to undo mine it wasn't easy the thread was very rusty. Interestingly it has different length.
Old 05-31-22, 10:12 PM
Mackers
Quoted: 194 Post(s)
Wait til you try and buy a Campagnolo binder
Procraft binders are about 2 euro over here.
Mackers is offline
