Would I have any issues using this Advent 9 brake lever on a bike with Advent X?
Microshift SB-M090-LD.
considering this brake lever with an integrated dropper remote. Typically used on Microshift’s advent 9 speed drivetrain.
would there be any conflicts using this on an advent X drivetrain bike? It’s a 1x drivetrain so I can’t see any potential issues but clearly I’m a noob.
Quoted: 327 Post(s)
Liked 736 Times
I believe Advent X (10 speed) and Advent 9 speed are not compatible for proper indexing, so you’d need to mate this shifter with a 9 speed Advent derailleur and cassette. Although I’ve never tried mixing them myself.
Edit: now I see that is a left lever with dropper remote, so it seems that shouldn’t be a problem with your current setup if you’re keeping the right lever the same.
