front derailleur limit screws not working
Old 07-05-21, 12:41 PM
AKHIker
Quoted: 16 Post(s)
Liked 4 Times in 2 Posts
Have a new front derailleur. Not seeing any movement in the standing derailleur no matter how I adjust the low limit bolt. Tried adjusting the high limit as well thinking it might be set too far in one direction for the low to be adjusted but still no movement in the standing setting.
Any tips or tricks?
AKHIker is offline
Old 07-05-21, 01:22 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 264 Post(s)
Liked 122 Times in 101 Posts
Any tips or tricks?
Look at the screws where they meet the derailleur. Take the weight of the screw by moving the derailleur by hand or with the shifter and then adjust.
blamester is offline
Old 07-05-21, 01:24 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
The limit screws will not move anything unless the derailleur is against one of the stops.
dsbrantjr is offline
Likes For dsbrantjr:
Old 07-05-21, 01:36 PM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 317 Post(s)
Liked 280 Times in 195 Posts
Undo your cable and set the low (L) limit first on the front DER, make sure your control is in low (1) and then re-affix the cable, then check your upper limit (H) as you move the control to the larger (largest) gear.
If you need more help, look at this page for text and video
Park Tool Front DER Adjustment
JoeTBM is offline
Old 07-05-21, 01:55 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Any tips or tricks?
Is the cable attached?
cxwrench is offline
Old 07-05-21, 01:57 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
You need to understand a LIMIT screw only prevents over travel of the DER so it doesn't go too far.
H keeps it from going off the Big ring and L keeps it from going off the small ring.
They have noting to do with indexing.
IF your FDER won't move, it's because you have the Limit Screws turned in too far.
Move the DER by hand to insure you have travel.
Bill Kapaun is offline
