Clipless Cover Users ->
Liked 2,966 Times
Those of you that have speedplay zeros, do you default in using the cleat covers or only slide them on when needed... or just not use them at all?
I'm referring to these:
https://www.wahoofitness.com/devices...leat-cover-buy
I ask only because of the high probability of them becoming roadside debris after a while of being used; They like to deform & fall off, if one is quick to cross an intersection in a hurry or alike situation.
-Oh Hey!
-Oh Hey!
Likes For Bald Paul:
I don't know.
Quoted: 317 Post(s)
Liked 852 Times
This is the first I've seen those covers, and I've been using zeros since 2004. That would have been nice all these years.
Liked 2,966 Times
I'll slip them on along with the plugs when I have to talk a little bit.
-Oh Hey!
-Oh Hey!
Liked 2,966 Times
It looks like the OEM caught on to the preferred colored [black] which would have saved an extra purchase of the knock offs that are already black.
Never had an issue finding them whenever they came off walking around if i forgot to plug the cleat area. Usually they are lost for good if they come off as described in the OP. I will not play frogger for them.
-Oh Hey!
-Oh Hey!
Likes For Broctoon:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
Not zeros, but been using the Keep on Kovers for the Speedplay X's for years. Never lost one or had one fall off.
Liked 2,966 Times
I've tried a few aftermarket brands, & the durability seems minimally different. The ebay cheap ones are the better value [quantity] as I'm less concerned about losing one, but it gets old having to be conscious when spinning off from a busy intersection.
I think shoe stiffness is a factor for them becoming a sloppy fit over time.
-Oh Hey!
-Oh Hey!
Quoted: 20810 Post(s)
Liked 9,456 Times
They're meant to be kept on there, not to be put on and taken off when you need them. In the time since the walkable cleats became available, I've never lost one. I did replace a set once, when one got smooshed pretty badly out of shape, but I've never had one come loose on me. I would suspect that you've either got an aggressive, twisting gait or (more likely) that you didn't get them on firmly enough in the first place, it does take a bit of work.
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
used the yellow ones for years. never lost one.
