CX vs. gravel BB height
I've been chatting with a customer rep about BB heights on their CX and gravel bikes. I'm confused as to their replies. Per our conversation, their BB are lower on the CX frames. I thought they would be higher for clearance on CX and lower on gravel for stability.
Yeah that doesn't sound right. Which manufacturer? Maybe you can look up their geo charts to confirm?
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: too many of all kinds
Liked 415 Times
Well, the current fashion is always changing, but typically what I see is
road bikes ~70mm.
CX bikes <70mm,
Gravel bikes >70mm drop (i.e. lower than CX)
(track bike 50mm).
low long and slack is the current trend in mountain bikes, and gravel bikes seem to be following suite...
road bikes ~70mm.
CX bikes <70mm,
(track bike 50mm).
FLIR Kitten to 0.05C
Liked 407 Times
Make sure you keep straight BB "height" and "drop". I could believe a gravel bike would have a higher BB than a CX bike. How? Tire size.
You make 2 frames both with 65mm BB drop....but one fitted with a 700x33mm CX tire, and the other with a 700x40 or 700x45mm gravel tire. Ta-da. The "gravel" bike has a (much) higher BB as measured from the ground. Why? Because bigger tire lifts the BB higher off the ground.
BB clearance/height is all about the tire size used when measured.
2019 Salsa Warbird
2019 Salsa Warbird
