Electra Townie 7D - tools, adapter recommendations
Hi - I'm looking to place a mid-motor on my 2016 aluminum townie. It appears to have the "American" bottom bracket, which is almost 100 wide, with an internal diameter > 35mm, according to the Bafang compatibility tests. I'd like to buy the correct adapter and any needed tools (I haven't really ever done any bicycle maintenance). Way in the distant past, I did rebuild a car engine, so I'm not completely helpless; for the past couple of decades I have just relied upon local bike shops for all maintenance. So - any thoughts, links, etc would be very welcome.
Quoted: 1943 Post(s)
Liked 2,164 Times
If you don’t get a response, post this in the Electric Bikes subforum. A ton of knowledge on conversions over there.
John
John
An American BB is usually a term used for BMX, cruiser and Schwinn shaped things. It's threadless, roughly 68mm wide-ish, and much larger than 35mm internally. I think some of the Electra bikes did have those, but it sounds like you have some variation of an English BB. They can be anywhere from 68mm to 100mm wide for a fat tire bike. Generally you would only get a 100mm width BB on a bike with 4" wide tires.
If it's standard English threaded all you need to know is the width, Bafang makes models for everything up to 100mm wide. You can easily get an adapter for an American BB too though, they press/bolt into place and you end up with a 68mm, or maybe 73mm English threaded BB to work with.
For tools the Bafang kits usually offer the couple tools you need. If the original BB is still in the frame that's could be a couple more tools.
Quoted: 880 Post(s)
Liked 817 Times
Look at YouTube for assembly of a Bafang mid drive. Luna Cycle has the specific tools listed for BBS; for TS look at ECO (procedures for Bafang are well-documented, but I've never converted with TS since they seem to have quality problems). For your bike, AFAIK you need an 8 mm Allen to remove the bolt holding the crank arm, a gear puller to remove it from the spindle and whatever tool is specified for the bottom bracket. Park Tool has these, but you can find more expensive and cheaper that will accomplish the same task. If you have any questions of a more specific nature ask on the e-forum.
Likes For 2old:
Likes For chrisstratton:
Quoted: 6191 Post(s)
Liked 4,806 Times
The spec's for a new Townie 7D are what sounds like BSA threaded bottom bracket.
https://electra.trekbikes.com/us/en_...Code=greendark
When you say 100 mm wide, you are talking about the shell, the spindle length or the chain line? The shell width should be pretty easy to measure without even taking it apart and be accurate to a millimeter or so. And if it's a cartridge BB and you have the tool, just remove the cranks and find out what that shell is.
Bottom bracket: Sealed cartridge 68mm/118mm
Using Bafang's cutout paper tool, I'm measured what they refer to as the width of the bottom bracket, the part of the frame which holds a spindle to which the crank arms are attached.
Quoted: 2337 Post(s)
Liked 2,820 Times
also a picture will really help
Likes For squirtdad:
Printed. Suspect…
It was one which was printed from online. Currently, I think it is suspect. Perhaps it is 67mm?
67mm?
8mm?
Lightweight 6061
Not sure if 35 mm
67mm?
8mm?
Lightweight 6061
Not sure if 35 mm
Liked 4,806 Times
I'd go with 68 mm.
BSA only has one internal diameter for the threaded part, 1.37 inches and only one TPI for the thread pitch, 24.
But it has several different shell widths. 68 and 73 being the most common. That looks like a common BSA threaded shell.
You might ask a Trek dealer if they have some way to look up what the spec of that year is. And if you know how to pull the cartridge, everything you need to know is probably written on the cartridge. Except for chain line. And that you can measure from the center of the seat tube to the center of your chain wheel.
But as to anything for Bafang, I've no idea what they'd want to know for a conversion or add-on. I barely know who they are and what they make. Electric doesn't show up in here too often.
