Bafang Motor question
Does anyone know if the nylon planetary gear & clutch is the same for Bafang Mid Motors as the Bafang Hub Motor.
I have a 750 watt rear hub motor and might need to replace the nylon gears but everything I find mentions only Bafang Mid motor.
Devil's Advocate
Devil's Advocate
Have you checked with the vendor from whom you bought the 750W Rear Fat kit? Good possibility they can get the part to you pretty quick even if it is not listed for sale in their store.
I have a RM G060.500.D motor
There are at least two different sizes. Do the measuring. I thought I could replace the bearings in the wheels, but they were totally stuck on the posts.
-SP
-SP
