Loose helmet mirrors: fixes, or suggestions for replacement?
Not a legend
I would like a helmet mirror that doesn't get loose so quickly. I've seen this thread for suggestions on repair. I currently have a Cycleaware. I tried threadlocker, but it isn't helping. I don't want to buy a new mirror (or parts) every year if I can avoid it.
I'd like a helmet or eyeglass mirror that can be removed and replaced easily (for helmet stowage) and doesn't get loose so fast. I've seen the ones that stick on the lens, but don't know how great that would be (and I have a few different lenses for my glasses, and they may not fit). Any suggestions? My mirror went from "moves only at 30+ mph" to "moves in strong winds" to "flops around uselessly".
Alternatively, additional repair suggestions wouldn't hurt but it seems like this model just is engineered this way (for what are probably safety reasons).
Bikes: Devinci Caribou, Kona Dew Plus, Raleigh Twenty
Take-a-look mirror. Its all metal, easily removable (I wear mine on sunglasses). And they have a guarantee against breakage. I think if something does break you can mail them the glasses and $2 and they'll fix it.
I have Third Eye mirrors glued to my helmets. If anything, they are almost too stiff. Never had an issue with them moving unless they get physically bumped. One of mine is on its second helmet and still going strong. Definately not removable, however.
Likes For CACycling:
Not a legend
Between the leverage and the weight it seems to pull down the glasses a bit, so I have to push them up once in a while. Anyone else have this problem, and if so how do you fix it?
The Professor
Bikes: Alex Moulton Double Pylon, Surly Big Dummy, Alex Moulton GT, AZUB TiFly
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
I have a cycleaware mirror also and ran into the same problem. I took the ball and socket apart. I took the socket and very quickly held it over a Bic lighter just enough to heat up the tangs on one side of the socket. One or two passes over the flame should be enough. I then squeezed them in ever so lightly. Not too much or the ball won't fit back in. It worked and I think the ball is a much tighter fit. Just don't overheat the tangs or you'll ruin them.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Which cycleaware? I have a Reflex, and it's about 4 years old and not loose at all. I guess if it got loose I'd try putting piece of paper or something around the ball and then pushing it back into the socket. Or maybe a piece of tape around the ball. needs to be able to slip though.
Work: the 8 hours that separates bike rides.
The good looking one
Bikes: gary fisher, Schwinn Woodland
+1 I use a piece of saran wrap or alum. foil, form it around the ball of the
mirror, than push it back into the socket. With the saran wrap I heat the
top of the wrap with a match, o keep it from comming loose. The mirror
is as tight or thighter when new, and has been going strong for about
9 months, now
9 months, now
alleged person
Bikes: 1970s Royal Scot 3-Speed, 2005 Breezer Villager 7-Speed IGH
Quoted: 8 Post(s)
Long-time Reflex user here. My fix for loose ball/socket joints is to disconnect and put a dab or two of nail polish on the ball, let it dry, then reconnect. This tightens the joint enough to keep it from from flopping around but still leaves it easily adjustable. May have to reapply about once a year, but it's quick, easy, effective, and foolproof.
Bikes: Trek Elite 9.8
Got the take-a-look. So far I'm a fan. Solid, great field of view. It's nice to see back there again!
Please pattern the design for yourself ~ or follow signature link.
Not a legend
Ah, there it is: https://www.marketingcounsel.com/beerview_mirrors.html
Not a legend
++ on take-a-look. I gorilla glue the mounting tab to my helmet and add another twist of wire to further secure the mirror wire. . .(had a poorly mounted one fall off during a road-sit "pit stop" in the trees) . But its the most durable, adjustable helmet mirror I've seen and I can't imagine using anything else. . .the plastic stuff just doesn't seem as well made or durable.
I used to have this problem with the third eye, eye glasses mirror but now I simply put epoxy on the joints, then adjust it while riding and the epoxy is still pliable. When the epoxy sets you never have to adjust it again. The other alteration I've made to the Third Eye is I cut off the three prongs you use to attach it to the eye glasses and use small zip ties instead. This holds the mirror much more securely than the three prongs. To remove just slip the zip ties off the front and back of the third eye "rail", remove the third eye and then slip them off the back of the eyeglass temple. Reverse to install the mirror (this won't work if you have eyeglasses where the temples thicken at the ends).
Appreciate the tip.
JD
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Third Eye is amazing. However, I just bought one made to attach to your visor with a screw on arm. I like it!
Quoted: 978 Post(s)
Liked 574 Times
I like the Third Eye glasses-mount and have used them for many years. When the joints get a little loose, they can be tightened by jamming them together. I may try that epoxy trick, thanks!
The closer the mirror is to the eye, the smaller diameter that will give an adequate field of view. For this reason, I prefer the glasses-mount over the helmet-mount mirrors.
Third Eye employs people with intellectual and physical disabilities, so buying their products also supports a good cause.
wannabe
I use the take a look and like it much. I drilled a few holes in my visor and ziptied in place. It only gets misaligned when I bump the mirror on something while wearing or storing the helmet. One disadvantage of the mirror is the sharp edges which I've heard cut a BikeForums users face during a crash. Never had that problem personally.
Quoted: 5218 Post(s)
Liked 3,564 Times
