Shimano Di2 Setup question
Hi,
I'm planning to remake my TT bike with Shimano Di2 electrical gearing. It'll be a 1x setup (no front derailleur). The plan is to put the Junction A EW-RS910 into the aerobar extension, and also the battery in the same extension. No junction B is planned. The RS910 has only two ports, so I have to use a JC130 Y cable. The question is: can I use the JC130 Y-cable to connect the battery in one of the cable and the right shifter in the other? I'll only use the right shifter since it's a 1x. Then a SD50 normal cable will go from the other port in the RS910 to the rear shifter.
PedalOC
PedalOC
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
1st - the RS910 I believe is much larger than most aerobars will accept. Same goes for the battery. You'd have to check actual measurements and fitment to be sure though. Theoretically ... 1 wire - Y - between battery and A junction...then the other end of the Y connected to a Di-Fly to use as a a coupler. Then a long wire to your derailleur.
BUT..... I can't tell you for sure it won't work but I highly doubt it will. The wire lengths needed and the physical space to put in what you want to put in... but yes, theoretically Di2 can run without a front derailleur and without a Junction B. You might find using a Junction B will make it easier though.
This is a fun intellectual exercise but as a design it kind of stinks. If you're doing it to save money and will be devastated if it doesn't work and you don't want to buy the needed parts then.... find someone who can wire it up with spares and show it works first.
Wiring aside - I really don't think you can fit everything in that you want to and make the wires that are there work. Physically.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Wire it up on a table first to verify it works, but it ought to. The battery is as pointed out probably impossible to fit in any handlebar, but it and the RS910 could be located on/in the bottom tube if you have a port or opening. You can string together multiple wires to the desired length; there's a cable-to-cable joint, forget the part number, but there's usually one at the front of the bike to allow disconnecting the handlebars. You can have any number of those, it's just a simple double connector.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
