Stronglight Competition 55 crank question
Quoted: 5888 Post(s)
Liked 3,471 Times
I have a stronglight competition 55 crank that I'd like to use on a 50s era Claud Butler I need to build up. That bike deserves a cottered crank. The chainrings currently on the stronglight crank are 52/47. I'd like to run smaller rings (ideally 46/36).
Velobase has a listing for that crank and it states "Ring sets had tooth ranges of 45 to 54 teeth."
https://www.velobase.com/ViewCompone...6-44B76354D545
It's a 3 arm 116 bcd crank. I thought you could go much smaller than 45 with those. Sheldon Brown's website says you can go as low as 36 teeth.
https://sheldonbrown.com/cribsheet-bcd.html
So what's the deal? 3 arm 116 bcd rings do pop up on eBay from time to time but I have no idea as to compatibility with my crank. Will I be able to go lower than 45 teeth on my stronglight competition 55? Are all 3 arm 116 bcd rings compatible? I'm guessing they're not, right?
ambulatory senior
Quoted: 1954 Post(s)
Liked 3,658 Times
The 3 pin cottered cranks that came on super courses routinely came with 52-42 combos. I have one I'd give you if it would help.
Likes For 52telecaster:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
I believe that any 3 arm 116 bcd chainrings would be compatible, though you may have to substitute bolts (shouldered vs. non-shouldered.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
If you use the Simplex rings and brackets you are indeed limited to the (very) large sizes:
On my Gitane I used a set of cheap take-offs from an entry level French mixte to get a more usable 50/38:
Liked 3,471 Times
I may just take you up on that! That 52/47 is tough on the rollers here in central Iowa. I can handle a 42/26 (which is the upper limit for the campy gran sport RD I plan on using).
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
3-arm, 116mm cranks were quite popular BITD; lots of manufacturers and interchangeable rings.
Likes For JohnDThompson:
