A Quick Pedal Question
Bikes: Raleigh Mojave 4.0, Panasonic DX1000
Quoted: 46 Post(s)
Liked 22 Times
Do these vintage "aero" pedals require a cleat of some sort? It almost looks like there would be some sort of clip in nature to it for a cleat to engage, albeit I don't see the point of that when there's also standard clips and straps. Considering buying a pair of this style to upgrade from flat, unserviceable pedals.
Quoted: 18320 Post(s)
Liked 4,489 Times
Like most toe clip pedals, they'll hold best with a simple slotted cleat. However, they are commonly used without cleats.
I ended up moving to SPD clips as as I was having troubles with foot position and flexible soles when using walking shoes for longer rides.
Likes For CliffordK:
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 676 Post(s)
Liked 447 Times
If those are the true aero pedals, they take a non standard 1"diameter axle
Likes For robertj298:
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,780 Times
Likes For Wildwood:
Quoted: 3449 Post(s)
Liked 2,800 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4311 Post(s)
Liked 2,954 Times
Likes For DiabloScott:
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
Some Shimano pedals of this era used special slotted cleats that also interfaced with the tabs on the front of the pedal. Yours, these 6400 pedals below, and some 105s for sure. I don’t know if the cleats interchange between models.
pic thanks to bicyclists_retreat on ebay
Likes For C9H13N:
Quoted: 46 Post(s)
Liked 22 Times
Based on one reply here and the look of the pedal, is it safe to assume I would be okay to forgo the cleats and just use them as standard clip & strap pedals?
Likes For Aerzon:
Edumacator
Quoted: 2385 Post(s)
Liked 2,931 Times
I have found getting a decent quality thinner toe box shoe makes the difference.
Problem is the little wings on the front piece stick up. I think you can remove them and the clip is fine.
Likes For jdawginsc:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 957 Times
Extra credit: the clips come in sizes. They should be marked, I find the medium and even large to be on the small side. The Dura Ace and 600 pedals came with metal clips. Lower models had a plastic/nylon clip that I often find cracked. Good metal clips are worth as much as the pedals themselves.
Likes For wrk101:
Quoted: 1629 Post(s)
Liked 814 Times
I'm a bit surprised than not that many prople used clipped, slotted cleat cycling shoes with their quill type pedals. I would think that using anything else could result in bad hot spots and pressure points because of the thin pedal cage against the bottoms of regular shoes.
People seem to be too worried about possibly not getting their feet off the pedals when they have to, but it's really easy to release the toe strap buckles with a quick flip of the wrist which becomes instinctive when stopping.
I remeber that it only took me one ride to get used to them.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Liked 4,489 Times
I seem to have misplaced my old cycling shoes, but I fear that my feet have grown in the last 30 years or so, so they may not fit properly.
Nonetheless, I always combine riding and walking, and found the old leather sole shoes without heels to be uncomfortable to walk in, and potentially dangerous on things like slippery stairs.
I'm not sure about shoes and the sculpted design of those pedals, although the typical cage pedals aren't fully flat.
Quoted: 46 Post(s)
Liked 22 Times
Quoted: 1924 Post(s)
Liked 1,954 Times
I'll be riding with those at Eroica CA with LL clips for my size 12 1/2s. Still working out my "cleat" with shoe sole material and Shoo Goo.
ambulatory senior
Quoted: 1953 Post(s)
Liked 3,633 Times
Absolutely. It was meant for slotted cleats but as was stated above, it also has a platform, toe clips and straps for riding fun.
Be aware that these Shimano pedals require non-standard clips. Clips fatigue and break; I am not sure you can find a replacement for these when they go.
Edumacator
Liked 2,931 Times
Edumacator
Liked 2,931 Times
I replaced the earlier 105 (1050 series maybe?) with SPD-SLs but I remember that version was a nice platform. Still have them. The later ones had the metal clips and the little winged thingy.
Quoted: 3430 Post(s)
Liked 2,824 Times
That piece acts sort of as a washer over the holes in the clip, which allow adjustment fore and aft. The screws holding the cleat are pan-head shaped, and probably should best be used with the piece, which is countersunk for them.
Liked 2,824 Times
Skate shoes have a very thick sole that should work well for this sort of thing. I reckon the sole on one of my pairs is about an inch thick and relatively hard. They feel quite nice for cycling just because they're stiff on the bottom like that. Not that it's optimal, but it's probably the best regular shoe type you can use.
Liked 2,824 Times
