Tire Pressure
#76
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 809 Times
..just goes to show..traditional physics aside, the apple can fall far from the tree.
Likes For fishboat:
#77
Quoted: 1391 Post(s)
Liked 1,852 Times
A Silca engineer, when interviewed, said that if you want to go fast you are much better off running pressure that is lower than higher. And he said this is because although there are gains to be made by running high pressure, they are much smaller than the losses that can occur from vibrations induced in the bicycle from the texture of the road surface. He said that as he and his crew were traveling around the world being technical support at races, they almost never used their tire pumps when adjusting the pressures of bicycles they adjusted for various riders, in almost every case they were letting air out of the tires they looked at.
This engineer said that the only surface that could use higher pressures would be a sanded smooth and varnished velodrome track, an outdoor concrete velodrome, although being very smooth, would not use higher pressure for optimal performance. So the take-away is that anyone riding on any sort of public paved road, is certainly better off running pressure that is low, not so low that there is any danger of damaging the tire in use, but not pumped up to the max pressure that is on the sidewall of the tire.
So I have been riding with lower pressures lately in my road-bikes, not worrying so much about them being pumped up to the sidewall pressure, but having them ten or fifeteen pounds lower. There are a few local courses I ride which have been used for time-trials in past decades, and eventually I will get round to timing myself on them while riding with lower pressures. All the science says that I should be faster with the low pressure, but I do not use any sophisticated methods of measuring, just the stop-watch feature on a wrist-watch over a dozen miles. I am guessing the low pressure will not hurt my speed at all, it may make me a little faster, and it will certainly be a bit less fatigueing, so all I see are advantages.
but there was one small but significant 'catch' that could quickly ruin your ride: snake bite punctures
if you ran less than 100 psi - you were inviting trouble - especially the larger / heavier riders
today rims and tires are wider - many run tubeless - so they are able to take advantage of this and run lower pressure
#78
Liked 1,852 Times
Again, I'm not a racer. I'm a casual rider. I guess I just opt for a bike that "feels" faster instead of one that "feels" slower. My actual time means little to me. But, feel free to keep on trying to convince me.
Now if I could just find some 700 x 20C clinchers that went to 140.
I can place you at the top of the rapidly growing list for these fine vintage 20 mm Axial Pro tires that have been out of use for 20+ years - with vintage Air-B latex tubes
But they have not been inflated during that 20+ year period - so I cannot guarantee 40 psi let alone 140 psi
Go small or don't go at all !
#79
Quoted: 2693 Post(s)
Liked 485 Times
back in the day when we ran 20 and 23mm tires (w/tubes) - we were able to determine (subjectivity) the bikes seemed to roll and feel better with lower air pressure on compromised road surfaces (if not most road surfaces)
#80
Quoted: 1557 Post(s)
Liked 1,732 Times
It looks pretty accurate to me too. But I disagree that smaller diameter rims require higher pressure. I have a lo-pro bike with 24" front wheels. My wife has a Terry bike with 24" front wheel, and my kids ride bikes with 650c wheels, so we have plenty of non-700c wheels in our garage and I've always pumped up the smaller tires same as the larger tires of the same width.
Likes For icemilkcoffee:
#81
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
WHAT CAUSES ROLLING RESISTANCE
To go faster, the first step is to identify what exactly is slowing us down. When looking at our tires we are looking at casing losses and surface impedance. Casing losses is the amount of energy that you are losing when your tire is deflected and loses heat. The other major factor sapping energy from the system is impedance losses.The best way to look at impedance is the amount the system is moved up or down based on a bump. For example, on a perfectly rigid wheel like something found on an in-line skate or skateboard if you hit a 5mm bump, the entire system is lifted 5mm off the ground.
When you move to a pneumatic tire like we ride on bicycles the bump is absorbed largely by the tire and the loss is felt in the heat of the tire deflection like we just talked about. The better the tire and the lower the pressure, the more energy is absorbed by the tire.
We have long been told that higher pressures are faster on the road. We thought that to be true and even “tested” it to be true. This is because all of the testing at that point had been done on roller drums which are extremely smooth surfaces. When the surface is extremely smooth like on a roller or a wooden velodrome casing losses account for the vast majority of rolling resistance which is why you would want to run pressures exceeding 140psi.
When real world testing started to be done by Tom Anhalt, he found that there was a breakpoint pressure. This breakpoint is where casing losses are no longer the leading contributor, but surface impedance becomes the driving force to slow you down. Below you can see his test that follows the same curve as the roller test closely on this “good” pavement surface right up until it doesn’t. The losses in the system shoot back up because it is now the surface impedance that takes over. The rougher the surface, the smaller the tire, the lower that breakpoint pressure is going to be.
These graphs lead us to the question of what pressure should we run. As with almost all marginal gains questions the answer is, it depends. What surface are you riding on, what size are your tires, how much does your system weigh, what kind of bike are you riding; all of these play a factor in the optimal tire pressure for the given conditions.
(remainder of article omitted as it gets more into details about tire types and the Silca calculator)
Also, note the higher slope of the surface impedance dominated part of the curve. This is what leads us to seek to err slightly on the side of “too low” rather than “too high” since the incremental energy cost is less for a given deviation from optimal pressure.
Otto
Likes For ofajen:
#82
Quoted: 1034 Post(s)
Liked 1,289 Times
Here is an article I posted before, but I am pretty sure, based on your continued posts showing your lack of understanding of the realities of the issue, that you didn't read it. https://www.renehersecycles.com/myth...ure-is-faster/
#83
Quoted: 1943 Post(s)
Liked 2,164 Times
It is pretty simple. The correct answer is based on what is used by those who actually get paid to ride fast.
There is a lot of data and people can argue all they want, but if professional cyclists are riding wider tires that is the most compelling evidence. And that evidence is mirrored in the lack of availability of 700x20 clincher tires that were so prevalent 35 years ago.
John
John
#84
Liked 2,164 Times
In golf there is a phrase, "feel is not real" because so many people feel what they are doing is correct, but in reality it is not.
In many sports, one's perception is not close to an actual video of the performance. That is, unless the individual is truly an elite athlete.
John
#86
Quoted: 20808 Post(s)
Liked 9,450 Times
But, since I'm such a nice, helpful guy, I'll even post it again, for the aggressively lazy - https://cyclingtips.com/2016/08/cycl...and-pressures/
So, there's the water. Are you going to drink?
#87
Quoted: 347 Post(s)
Liked 418 Times
@ofajen Otto, Doesn't the Silca site show this is a real but marginal gain?
Crr is the proportional amount of force needed to move some weight some distance at a constant speed.
Let's take me and my bike together are 80kg (before stopping for chicken fried steak).
The difference between the lowest and highest Crr is about 0.001
0.001 * 80kg * 10m/s*s = .8 kg-m/s*s (N)
Or for me about 9-11s difference over a flat 40km at my FTP.
In a TT that would be a little over an hour for me, yes I want those 11s really badly! But daily riding probably not that noticeable.
#88
Quoted: 6943 Post(s)
Liked 10,944 Times
People generally don't go out of their way to educate the belligerently ignorant. I've previously posted a link to a podcast - one doesn't even need to muster the motivation to *ack* read something - so don't complain to us that you've ignored it.
#89
Liked 9,450 Times
#90
Liked 10,944 Times
#91
Quoted: 4387 Post(s)
Liked 4,828 Times
John
John
#92
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Also, that graph is for a surface where the break point is 115 psi for a 700x23 tire. The surface impedances I ride on are a lot more.
Otto
#93
Liked 1,289 Times
So, if you go under the recommended pressure on car tires, you lose fuel efficiency. The recommended pressure for most cars, is under the maximum inflation pressure for the tire. So you haven't hit on any gotcha, with the exception of confirming what people who actually understand this issue have been saying, tire pressure is based on the weight the tire has to carry. It really is that simple.
#97
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
#98
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 896 Times
Moreover, the way he's treated here by some folks disgusts me.
Likes For Fredo76:
#99
No, the proof that removing weight from wheels makes a trivial difference compared to removing the weight from anywhere else in the system came from direct field testing (the earliest I'm aware of is Kraig Willett's from 2001). The model just explains the empirical finding.
Likes For asgelle:
#100
Liked 4,828 Times
The clowns happen to be correct though.
