E-bike from scratch
E-bike from scratch
Dear community,
I would like to build my own electric bike. I watched a lot of different videos on Youtube, but I could not really find what I searched for. As I mentioned in the title I want to build it from scratch. I don't want to use a kit.
So I thought about using a motor from Hobbyking like this one: Turnigy RotoMax 1.40 Brushless Outrunner Motor After a little bit of calculating I think I would need a gearbox with 1:30 to use such a motor on a bike.
At 35kmh the rpm of a 26inch wheel is 281rmp.
And the rpm of the motor at 37V is 8436rpm.
-> 1:30
I think with the appropriate ESC a controller and a battery this should work. But how can I convert the rmps?
What do you think? Am I right? Have you any suggestions how to use such a motor on a bicycle? Are there gearboxes I can use?
Thank you in advance!
-> 1:30
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
If you want to get that technical, you want to be on endlesssphere.com
Are you thinking of a friction drive, or what?
I’m not sure why you want to re-invent the wheel. Is it for the technical challenge or to do something new? I doubt you’ll save any money over buying from a wholesaler like bmsbattery, elifebike greenbikekit or similar.
Look at the kits from BMSbattery, to give yourself a BOM (shopping list). 80-50% of the ebikes on the market use these basic parts as a building block em3ev.com has a lot of good technical data and some good kit ideas.. Go to ebike.ca calculator to design your components.
