The best headlights under $50 thread
#301
Bikes: 1983 Trek 400 fixie, Haro Mary SS 29er, BMC SLX
Around that price I really like the Princeton Tec EOS (https://www.bicyclecities.com/browse.cfm/4,410.html). It has three brightness settings plus a flash, and you can mount it pretty much anywhere. It's easily the brightest standard-battery light I've seen--and I'm a total headlight junkie.
#302
https://www.shiningbeam.com/servlet/t.../24/Categories
#303
Bikes: 2009 Rockhopper Pro, 2008 Giant Anthem X3, Mercier Corvus AL
Been cycling for about 4 months now and love it but am without a good light. I have a Zefal but doesnt do anything for seeing at night. Its strobe ability does help with being seen. My budget is $50, I could go a bit more if need be.
I definitely need something bright enough to see on streets with no lights. A charge of 1.5hr is more than enough.
Thanks for the recommendations.
#304
I have been looking at the Solarforce L2, with one 18650 and charger which comes to $52.
However I am not really sure about what drop in to get and at what mode, any help would be appreciated.
#306
I was going to buy from sbflashlights.com they have a combo deal for charger, battery, 1 mode dropin 6-18V for $45
if there is a better site let me know.
#307
Maybe my requirements aren't as high but basically I like and LED light that is bright enough to ride in the dark with. I like it to be small and lightweight and the mount to be well designed. This $20 cateye works for my commute in the dark every morning.
https://www.amazon.com/Cateye-HL-EL13.../dp/B000R5NR9O
#308
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I also have the cateye uno which is lighter and throws a brighter but narrower spot. Its my backup light on the roadie. Battery lasts for ages.
#309
What is the latest recommendation?
I would prefer compact (short length) flashlight but am not opposed to two AA if it is clearly a better option. I don't need more than 2-4 hours of run time. I would rather carry extra batteries and stop to switch out than have a longer flashlight with a long run time. Most importantly I want a wide bright beam. I plan to attach to the stem probably with a two fish bikeblock (will this fit?) or a two fish lock block
I will be charging batteries with this beast (I was an early adopter of rechargeable batteries. This guy has been going strong for 6-7 years). It says it is for NiMH and NiCd batteries. I am guessing it will not charge lithium or shorter cr123s? Is it worth it to invest in a lithium battery charger? Will I get a significent lumen benefit?
#310
Yes, it's worth it to invest in decent lithium batts and a charger as the light will be significantly brighter. Personally I like AW brand batteries as they have excellent quality control and the 2600 18650 batts have great capacity. I would get the 2200 though as their capacity is quite disappointing. If you are on a very tight budget DX also has some, but do your research first. Last I checked the black TrustFire were the best they sold.
#311
https://www.shiningbeam.com/servlet/t...h-C3-II/Detail
What about this light? It is compact but will the max output be sufficient? Or will I need something larger with more batteries i.e. volts?
#312
The Solarforce L2 is another good choice. I'm very happy with mine. I'd go for the 5 mode 4.2v dropin.
https://www.sbflashlights.com/Solarforce-L2-p4.html
#313
i want a 18650 battery be seen throw light for around 20 bucks. i bought a q5 14500 light a while ago and well the battery last maybe an hour on flashing(flashes twice a second). really want 2-3hours on sos and preferably with memory. i will pair with a flood light for cycling. had a p7, but it died after a year, and was thinking of getting a SST-50 to see the road and all.
narrowed the be seen light down to:
SKYRAY XPG-R4
https://www.dealextreme.com/details.dx/sku.32749
or UniqueFire L2 Cree XPG-R5
https://www.dealextreme.com/details.dx/sku.33549
for see/flood lighting:
sst-50
https://www.dealextreme.com/details.dx/sku.33617
or p7:
https://www.dealextreme.com/details.dx/sku.16092
i just need a little push to pull the trigger. btw magic shine won't work wel for me. i leave my bike outside and don't want the light to be stolen. seems like a hassle straping down the light and the battery every time. a flashlight take all of 2 seconds to mount and dismount.
SKYRAY XPG-R4
sst-50
or p7:
#314
Quoted: 5 Post(s)
Ok, I read this thread twice and my head is spinning with so many options. I'm looking for a light, a set really for head and tail, for early AM riding. The time change turned my normal ride time into darkness, though the sun will come up as I am winding down my ride. I'm mostly riding on non-car paved trails with no light of their own, but have to ride some streets to get there. I have a ton of Ni-MH rechargables in AA and AAA, but no Li ion. I don't have any mounts, so I need those two, and would like to keep everything around the $60 range, but care about safety and function and so an somewhat flexible (but not Dionette flexible).
I think the Blackburn Mars 4.0 seems like a good way to go for the tail, but I haven't been able to figure out what to do up front. Please help, because I can't figure out all the choices from this thread.
Thanks in advance!!
***EDIT
I realized I left off the part about not wanting an external battery pack...I am hoping to have the lights mounted on the bike and self-contained with rechargeables.
Thanks in advance!!
***EDIT
#315
Thanks in advance!!
***EDIT
Thanks in advance!!
***EDIT
#316
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
Thanks in advance!!
***EDIT
Thanks in advance!!
***EDIT
https://www.shiningbeam.com/servlet/t...II-Cree/Detail
https://www.dealextreme.com/details.dx/sku.3609
"Without music, life would be a mistake."
-- Friedrich Nietzsche
#317
Bikes: Specialized Sirrus, Giant Defy 1
I just picked up a pair of l.e.d. flashlights from Costco for $14.99(originally $19.99). They're crazy bright and have three modes to use(50% power, 100% power, and SOS/strobe mode).
Pkg. says it's 160 lumens, lights up to about 100m, and should last up to four hours off of three AAA batteries. All I need to do is get a pair of flashlight holders to mount to my handle bar and I'm set.
#318
Bikes: Raleigh Mohave 8.0
Go to shiningbeam.com ( Brian is great ) and get 2 Romisen RC-N3 CREE Q5 LED Flashlight's. They're 220 lumens each and they're about $45. for the pair. They run on 2 AA's and come apart (unscrew the extention) so you can run them on 1 AA. Get a couple of fish mounts from Jenson USA for $18 and you'll be good to go. I been running mine for a couple of years. No worries. When I first joined this forum, I had no idea about lighting. All the bicycle lights I looked at were in the $200.+ dollar range. I got a heck of an education here and saved a lot of money. Get the cree Q5 LED and forget about the over priced bicycle crap.
#319
I agree with Ziemas. Shining beam is top notch. They actually hot rod the lights. They're better than DX. I have friends who thank me many times over for telling them about shining beam.
#320
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
I wouldn't even bother with Dealextreme. They're in Hong Kong and a hassle (so I've heard) to deal with. Shiningbeam is in NYC and has great customer service. And fast shipping.
#321
cyclepath
I got the dynamite little 1XAA Romisen one each from Shingingbeam and Dealextreme. The first was $20 the other was $10. One was fast shipping, one was slow. Both lights work great. It's nice to have the choice if nothing else.
#322
Bikes: Ridley Fenix Disc '15, Centurion Ironman '86, Raleigh Team '90, Bianchi Nyala '93
My current headlight is an ancient Cateye halogen with about 3 hrs runtime. It takes 4 AAs. I have a set of rechargeable AA's and I like them as they are readily available and reasonably priced. I was really thinking about a Planet Bike 2W until I found this thread.
My morning commute in darkness or twilight is only about 30 minutes, but I've started doing some training rides in the morning, as well, out into the country where it's darker and I start and finish before morning civil twilight.
The PB 2W is about $60 + shipping, I've found. Can I do better than that in output/runtime/price combo? Flashing mode would be a plus, but not a must-have.
#323
Bikes: Bacchetta Giro, Strada
https://www.dealextreme.com/details.dx/sku.12060 $28.04 light
https://www.dealextreme.com/details.dx/sku.8274 $1.80 mount
https://www.dealextreme.com/details.dx/sku.5790 $8.10 two batteries
https://www.dealextreme.com/details.dx/sku.1251 $12.30 charger
The light only takes one battery at a time, but they come in two packs, so you'll have a spare to throw in your tool bag.
At full brightness (400 lumens?), it lasts about 90 minutes (on one battery). At medium brightness (200 lumens?) it lasts about 3-4 hours. At low brightness (100 lumens?) it lasts about 8-9 hours.
The PB Blaze 2w is about 100 lumens at full brightness, lasting five hours on two AA batteries they say. So in low mode, the DE light lasts a bit longer with the same output, or a bit less time with twice as much light. (And at the price I give above, you also have a spare battery, so you can double these times.)
For the cost of the Blaze 2w + some rechargeable batteries, you can almost have two of these lights.
Now, the Blaze has some advantages. (I've got the 1w version -- I'll assume the 2w is the same, just brighter.)
-- It's more rugged -- all around, better construction. These flashlights have glass in the front that can break, and vibration can make them change modes (which can be reduced by putting a shim around the battery and some magnets on it to make it sit tighter.)
-- It's flash mode is awesome -- the DE light has a reasonable flash mode as well, but it's just a basic flash -- the Blaze's flash mode has an actual pattern and it's great.
-- The Blaze also has a better beam pattern -- it's more tightly focused.
I'm not saying these are the best lights ever -- the Magicshine light is basically a bike-light version and superior in a few ways -- but for the price they're hard to beat. Really, if I wanted to spend $60 on a bike light, I'd suggest $90 on a Magicshine, or $50 on the light I'm talking about.
#324
If you want to stay with AA you might want to check out some of the new lights with the latest generation R5 led. I have one (not for biking though) and it is considerably brighter than the Ld2, with a much larger hot spot, which means that more of the road get lit up. The downside is that they don't throw as far as the older emitters, but personally I don't think it's much of as issue.
As for best 'bang for the buck', I think that's with lights that are powered by 18650 li-ion rechargables. Once you get over the initial outlay for the the batteries and charger you not only get a considerably brighter light than with AA batteries, but you can also upgrade your light easily and inexpensively when new LEDs come out by simply buying a new drop-in. (A drop-in is akin to a bulb.)
I like Solarforce lights as they are inexpensive and well made. You can get the light for $34 shipped. The charger and batteries should cost another 25-30 dollars.
https://www.sbflashlights.com/Solarfo...rce-L2-p4.html - I'd go for the 5 mode (it has strobe for daylight riding if you need it) in 4.2v. Whatever you do, if you choose one of these lights make sure you get a drop-in that's 4.2v as it will be much brighter on one battery than the 18v ones will.
#325
Quoted: 9 Post(s)
I had a $25 REI gift card to spend. So I bought a Fenix L2T v2.0 Cree they had on sale. So it only costs me $20.
REVIEW OF THE FENIX L2T v2.0 Cree LED FLASHLIGHT. Brightness-wise it outshined the Romissen. It should. It’s 160 lumens compared to 110 lumens for the Romissen. But the battery life of this thing sucks. I used the same rechargeables that I use in the Romissen and the Fenix doesn’t even last ½ hour before it starts to dim out on me. The Romissen lasts about 2.5 hrs. Too bad. They made a nice combo. I’m going to buy the new RC-N3. With the new emitter in it. It makes it 2x brighter for the same price. I’ve had mine for over 2 years now and it hasn’t let me down. The Fenix is being returned.
