Schwinn S5 and S6 Rim
Is there a real difference between a Schwinn S5 and S6 Rim?
Reason I'm asking is because the Schwinn Im working on has both S5 and S6 stamped rims.
thanx
-james
thanx
-james
Likes For jamesj:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
https://sheldonbrown.com/tire-sizing.html#fraction
RUSA #7498
Originally Posted by noglider
Last edited by ThermionicScott; 01-30-22 at 02:03 PM. Reason: Incorrect! Read later posts.
Likes For ThermionicScott:
Huge difference. S-5 = ISO 547, S-6 = ISO 597. Any chance the stamping is smudged on one of them?
Likes For roadrunner2012:
Liked 2,568 Times
No kidding? Schwinn used the same codes for tire sizes *and* rim types?
Thank you for the answer!
They are both 26" rims, I just wasn't sure about the marking s on the rims. They are not stamped good and I was barely able to read the stamps.
Quoted: 380 Post(s)
Liked 106 Times
S5 rims are wider than the S6s and have a different shape. The diameter for a given wheeel size is the same. The S series is really about the shape of the cross section the rim than anything else. Imagine what you would see if you hack sawed through the rim. Roger
Likes For rhenning:
here are the stamps.
Here is the one I think says S6
Looks like S5 to me.
Likes For jamesj:
Quoted: 790 Post(s)
Liked 1,761 Times
Those both look to be S6 597 which should be fine for your bike. You should be looking for 26inch 597BCD tires. These are often refered to as Schwinn 26'' or Schwinn S6 tires. There should be markings on the tire if you have them listing the tire type.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
Old Schwinn...........the gift that keeps on giving.
Likes For 3alarmer:
It's a 1966 coppertone Schwinn Racer.
And Thanx for helping me out on the tire sizes.
Likes For jamesj:
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 850 Times
Wheels for a 1966 racer should be 26 x 1 3/8 nominally, but the Schwinn ISO 597 size. Tires are still made, but not as nice a variety as English size.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
I know this is an old thread but i'm running into a problem with S6 tires on S5 stamped rims.
They are not fitting very well.
I've bought some new Kenda 26 tires for S6, and they also are not fitting very well on these S5 rims.
So it looks like i'm finding out that S5 rims take a different tire..
Likes For jman0war:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I usually have to spray rubbing alcohol between the tire beads and rim walls just before inflation, so as not to have a serious "low spot" on the tire's rolling diameter, and even then it can take several tries, deflating fully each time.
This very tight fit of the tire bead around the inside shoulder diameter of the rim allowed Schwinn to use their standard rims on their tandem bikes, allowing much higher inflation pressures.
But it can also make it impossible to get a repaired tire seated evenly out on the road! And so you get to ride home on a thumping tire.
Likes For dddd:
Likes For jman0war:
