Kenesis Crosslight fork… hub spacing, dangerous?
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
Kinesis Crosslight fork… hub spacing, dangerous?
Is this Kinesis Crosslight aluminum fork safe with this hub? The hub spacing is probably 100mm, it’s an old sealed cartridge bearing Suntour. There is a space between the the hub nuts and fork ends. Are these forks intended to be spaced to 110mm? Is 110mm spacing for 20mm thru axles only? I acquired someone’s botched together bike and many parts haven’t been assembled in a safe or sensible manner. Can I just safely force the fork ends to contact the hub with the skewer? Seems like it might be a bad idea considering the fork is aluminum. Can I space the hub to fit better? Would there be enough axle and skewer? Why do I keep finding front forks that are spaced much wider than the hub? Does this happen from people using trainers? Strange
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Not in current configuration but that is not the on the fork or the hub but the user who has not done up the quick release properly. It looks to be in the open position and the wheel might not even be seated in the dropouts all the way.
Here is a good video on QR skewers and maybe a bit in depth and nerdy but will tell you everything.
It would be a very odd and ultra rare thing to find a 110mm spaced non-thru-axle fork. Boost spacing is relatively new or is old DH stuff but this fork is probably designed for a standard 100mm hub.
Now would I want to ride on a aluminum fork, not really if I can avoid it. It is not unsafe but just no real springiness or vibration dampening you would get from say steel or carbon respectively but still perfectly rideable and fine.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Likes For boneshaker78:
Clark W. Griswold
Liked 3,993 Times
I opened up the skewer to show the extra space between the fork and the hub. I’m aware that the skewer is not secured. I’m pretty convinced myself that this fork was intended to be 100mm spacing. Why it is spaced quite a bit more than 100mm is what surprises me. I wouldn’t ride an aluminum fork either, but I’m poor and this is a budget build, so I got what I’ve got. Still not sure if it is wise or safe to force the fork ends together to secure the hub, but I’m starting to think it doesn’t matter all that much. It would appear that the fork was forced into this wider position at some point, but perhaps they were just made this way and I’m being overly critical.
Likes For veganbikes:
Quoted: 4201 Post(s)
Liked 3,860 Times
I don't think the small amount of pull up will increase the fork's chance of cracking. Certainly not anytime soon. I suspect the fork just widened during the welding and was "good enough" for the QC pass. What I would do is to add a thin axle spacer on each side/end of the axle, under the lock nuts, to widen the "working length" to closer to what the drop outs are at. Do take care with the retightening of those lock nuts. No bearing likes to be overly preloaded.
I also would get rid of that external cam QR skewer. At least you don't have disk brakes though with that skewer Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Quoted: 5781 Post(s)
Liked 2,578 Times
This is a standard 100mm fork. Either it was made this way, or was spread at some point, it's now slightly too wide.
There is NO SAFETY ISSUE here, but there may be an inconvenience factor, in that the wheel might not easily slide in without backing the QR open more. If it were mine, I would double check the alignment, then bend (cold set) it back to where there's a correct slide in clearance for the hub.
Otherwise, feel free to use this fork as is.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 3,860 Times
For a few reasons. External cam QRs generally have less gripping ability. Between the plastic surface the cam acts on (and its compression under pressure) and the usual Al ends that bare against the dropouts (that won't embed as well into the DO surface, at one time the CPSC required a QR to emboss into that drop out) these types of skewers do a less able job at securing a wheel in the frame.
A common issue bike shops see is a "modern" replacement rear wheel that has been installed in an older bike that has horizontal rear axle slots. These QR skewers can slip forward on the drive side from the tension of the chain (when pedaling hard). While the resulting tire on chainstay rub is not a major safety issue (although paint and rubber will be lost and you'll be slowing down from the braking nature of this rub) if this were a front wheel with a disk brake (on a more modern bike) the reaction force the disk brake creates can eject the axle from the drop out. Sure most forks these days have dropout tip retention tabs (called lawyer lips) and more and more disk brake forks have the dropout slot angle changed to one that resists this reaction force better but still those are your back up systems, not the primary reason why you don't crash. The last issue with these skewers is that the plastic cam loading surface can get gauged up and deformed (especially is the rider is too ignorant about not using the QR lever like a wing nut) with less than best use. So over time the skewers ability to provide a strong clamping ability decreases.
My comment about your not using disk brakes was an attempt to let you off that hook. Andy
AndrewRStewart
AndrewRStewart
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Thank you everyone. I’m an anxiety ridden guy who likes everything to be as right as possible. I appreciate all of the advice.
Really Old Senior Member
I would verify it's the fork just to be sure.
100mm = 3-15/16" if you don't have a metric scale.
I think you mentioned budget build which, to me, says some parts may be sourced from places unknown.
It'd be a bit silly to discover the spacing on the hub is "undersize".
IF the hub is undersized, I would add equal spacers on each side to better match the fork.
One can't tell from your pics if you have an equal amount of spacers on each side of the cones.
In the end, you want the fork end flats bearing parallel" to the locknut flats.
Too much of an angle and you'll bend the axle slightly when clamping.
Likes For Bill Kapaun:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Quoted: 883 Post(s)
Liked 822 Times
I have used that same fork intermittently for 15+ (probably more like 20) years on a rigid MTB (used as a spare bike for guests), without any problems, and consider Kinesis a well respected manufacturer of quality aluminum components. My fork has a dropout width of 100 mm, and I suspect that if yours is different, it was "cold set" somehow. I would be careful when adding spacers to the axle since you'll reduce the width of the axle ends that protrude into the dropouts. If the fork is only a couple of mm's too wide, it should be OK since FME, these are overbuilt (but inspect it frequently, especially the dropouts).
Likes For 2old:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
If you're getting 110mm as your front spacing, then something is amiss, and you want the best opinion you can get. If someone tried to "re-space" this fork, then it is compromised. Talk to the manufacturer:
https://www.kinesis.com.tw/en/
Likes For 1989Pre:
Quoted: 4806 Post(s)
Liked 3,928 Times
boneshaker78, in your first photo, is the open QR forcing the fork in at all? Or is the fork relaxed? If that is its natural state, I would absolutely not sweat forcing the fork in with the QR (though I would drop calipers over the hub and check for 100mm).
I would not (ever) coldset an aluminum fork, simply because I have lived through one aluminum fork failure. I know first hand how aluminum can crack instantly into two pieces long after whatever event that triggered the crack. When you force those blades in enough to bend them, the highest force will be at the weld of the blades to the crown and steerer, Not a place where you ever want 2 pieces instead of one. And it will almost certainly happen while riding if it does. (Mine on a routine bunnyhop I'd done hundreds of times on three bikes.)
Now, I do not have an issue with spacing out the hub a little with spacers so it drops in easily with no additional opening of the QR nut. Yes, you want enough axle protruding that aligning the wheel is easy and certain but after that, it doesn't matter. A proper QR with hidden cam and steel skewer tightened correctly is all you need. I see that QR is on its way. And yes, that hub with additional spacers is a "botched" job, but - not breaking aluminum forks comes first! (Now an 'incident" like mine is now no big deal Every local hospital has a CT scanner. It took the hand of the Almighty to put me within 20 miles of the only available one in the country and in addition, have a dad who knew what they were and where it was.)
Likes For 79pmooney:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Bicycle Frame Fork,Bicycle Frame,Bicycle,Bike - Kinesis industry CO.
Likes For 2old:
Quoted: 1109 Post(s)
Liked 1,200 Times
Is there 110mm front hub spacing that someone would have re-spaced for? And could it even be done on an aluminum fork? I If there is a 110 mm hub and IF it was repeatedly spread to cram the wheel in place, would it set that way?
I'm asking that because my initial thought was that it was an immaterial deviation from perfect.
I won't discourage the OP from whatever safety decision he makes, but it looks like something I'd just clamp down. But I'm not the expert on this.
Likes For Camilo:
Standard Member
Liked 940 Times
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
https://aroundthecycle.com/products/...-quick-release
Standard Member
Liked 940 Times
I measured the hub last night and it was 100mm. I suppose it is possible the fork was manufactured to this wider tolerance, but it seems like a lot to me. After looking the fork over and sensing how robust it is, I’m going to clamp it and forget it. That being said, I was preliminarily shopping around for solid, affordable options to acquire a different fork. A used Tange Prestige TB fork caught my eye, I will probably try to source something similar when the time comes I can afford something.
Likes For 1989Pre:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Give Kinesis a call though, and find out if they ever made the Crosslight in 110mm spacing. For what it's worth, I recommend Kinesis aluminum forks. I run the Maxlight in summer on my mtb and the Road-D on one of my road bikes. Definitely throw a 2mm washer on each side before you tighten the quick-release.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
The lesson for myself in this instance is that accurate measurements should always be taken prior to making any assumptions. I shouldn’t be so lazy next time and I should investigate what is really going on with the use of measuring devices. I’ve noticed that angles can play games with your mind when viewing certain things, optical illusions can occur when trying to sight if something is straight, or in this case, what the distance between something truly is.
Sorry to drag everyone down this investigative path due to my laziness and thanks for all of your help everyone. I appreciate the persistence of the community to see what was truly going on here, it led me to the conclusion that the fork hasn’t been as damaged as I once thought.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Here is an image of the amount of axle left after spacing it out, which I hope and assume is enough for the fork ends to sit on. The other image is of the hub sitting between the fork ends after it has been spaced. Much better IMO! Thank you everyone.
