Front rings skipping after new chain and cassette- best "cheap" way to handle?
I recently replaced my rear cassette and chain and rode for about 500 miles trouble free... Recently when peddling under heavy load the chain is skipping- I think in the front.. I am guessing my front rings are too worn now (see pic)? I think this is an old Sugino(?) crank... Is it possible to find chainrings for this crank? Can I just buy any chainrings that match my BCD and use 4 bolts?
This is an old steel frame Specialized MTB I got second hand nearly 25 years ago and have been replacing parts as needed myself to keep it going as my day to day hauler... Any tips for cost effective fixes appreciated!
Quoted: 453 Post(s)
Liked 104 Times
From the picture, there is a lot that needs replacing.
Your chain is probably the biggest issue, it's long worn out, which can clearly be seen as it doesn't sit on the outer chainring correctly (it sitting on top, rather than on)
Your FD is missing a screw, probably not causing any issues, but not helping either
All the chainrings look excessively worn, realistically it will probably be cheaper to just replace the whole crank , rather than try and source the chainrings; would be looking at a lower end Shimano HT2 compatible crank, yes the BB will also need replacing, but once it's done, any future repairs are easier than trying to source a crank/BB that match each other.
You may also want to check the pulley wheels on the RD, if they are anything like the front, they will probably need replacing.
For cost effectiveness in the future? get you kit clean, learn how to lube a chain, as it will last longer,
Your bike has done 25 years, it's time to refresh some of the parts on it, sometimes you can get away with replacing 1 or 2 parts, sometimes (like now) you need to replace a lot more. (wondering what condition your cables are in as well)
Likes For jimc101:
104/64 BCD.
5 second search on AliExpress yielded a three ring set plus replacement bolts for around $20.
Complete crankset isn't much more but may open another can of worms
Likes For Mackers:
Friendship is Magic
Bikes: old ones
Quoted: 26394 Post(s)
Liked 10,367 Times
...the most cost effective way to keep a bike like that going is to find a bike co-op in your area, and buy used parts and components to keep your old utility bike going there. Depending on the size and age of your organization, they have some pretty extensive parts inventories ...at least the one near me does. Try Google using "bike co-op" and "your town". The crank in question doesn't look like replacement rings would be a big expense. But I think you might have to replace the chain and rear cluster again, because those wear pretty quickly when your chainrings are worn out like that.
Likes For 3alarmer:
A new crankset might be the easier path, his crank looks like one of those low-end ones from the early-to-mid-'90s with three steel rings riveted together and mounted on the one set of bolts we can see. I believe we're looking at 64 BCD here, no 106 holes.
Likes For Joe Remi:
This advice is for a home mechanic who's pulling their own cranks and can determine if the bottom bracket is still good. If you're going to a bike shop they'll have an idea for a new crank/BB that will work for you. You definitely need a new chain, too. The cassette may be ok.
Likes For Joe Remi:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 809 Times
If you've gotten 25 years of use out of the bike, it's time to drop a couple bucks on refreshing the components. To be really honest here..by the look of the pics and the degree of wear on the components, maintenance isn't your strong suit. I'd take it to a bike shop and have them do the work.
Likes For fishboat:
Miles to Go
Assuming your bike is 7/8 speed, and if it were me, I would go with something like this:
https://www.jensonusa.com/Shimano-Al...70mm-22X32X42T
Forget trying to source new rings. Cheaper, and a lot less hassle to replace the entire crankset.
Most certainly as part of the job invest $12 in a new chain.
Likes For timdow:
Quoted: 453 Post(s)
Liked 104 Times
They did some with 'normal' Shimano compatible rings (5 bolt), the ones that the OP has, have only seen in pictures, but look to have a non-standard BCD for the outer (had a 5 bolt, they were normal Shimano 5 bolt compact compatible), getting a replacement now, 25-30 years after they first came out could be problematic to impossible; not to surprised as these would have come out right around the time Shimano went to 4 bolt pattern, and even Shimano had some designs that are no longer available.
Sugino Impel, that was good mid range stuff in the mid-late 90's STX level, what would currently be around Deore level.
Likes For Joe Remi:
Quoted: 476 Post(s)
Liked 427 Times
The chain looks worse than the chainrings. It wouldn't hurt to clean the drivetrain occasionally, it will work better longer that way. Is it cheap off-brand stuff?
Likes For grumpus:
Quoted: 957 Post(s)
Liked 1,619 Times
500 Miles is admirable but dam man... Clean up that bike, get out your tool kit, and do some maintenance. Ya just don't ride a bike down to its failure point and then consider whats whats wrong. I don't mean to be harsh but you know this...
Edit 2023-02-08: OK... Here are some possible solutions. If you don't know how to make the replacements just do the old YouTube search. Remember that the purchase of the tools and the parts can still be less then the cost of someone doing it for ya. And of course even if ya pay there is no guarantee they will do it right. All bicycles deserve routine maintenance, and to, they all wear out, no matter how little or how expensive the original cost.
Amazon 15 USD
Amazon 18 USD
Amazon 15 USD
Amazon 18 USD
Likes For zandoval:
Thanks all for setting me straight on keeping up with basic maintenance- and also for slapping me into realizing the chain was the most worn thing in the picture (seems obvious to me now looking at how the chain wasn't seating in the chainring)- I got a new chain, cleaned up the gears a good bit, and put things back together and it peddles smooth and strong now without a hitch. Since my rear cassette is still pretty new- a little cleaning there, and on the derailleur. My drive train is operating, if not looking, good as new
Likes For cruiserandmax:
Learning is good! Wipe the chain down every now and then and put some lube on the rollers and it'll last you a while.
Likes For Joe Remi:
Quoted: 476 Post(s)
Liked 427 Times
I tend to just oil and wipe, but if it's been wet I'll occasionally take the chain and cassette off and clean them properly - seems to be a Sunday afternoon activity.
Likes For grumpus:
