Presta valve inner tube for Brompton
I have Schwalbe Marathon plus tires and want to switch inner tubes to Presta valve ones. Which tubes would suit best?
Will Presta fit to the rims or do I need to buy an adaptor or something?
Quoted: 800 Post(s)
Liked 247 Times
The hole for the Schräder valve is bigger, too big for the Presta valve (rims for Presta valve have a valve hole with a smaller diameter than rims for Schräder valves).
You need an adapter ring to avoid any damage to the inner tube that could eventually cause a leakage around the valve.
The Schwalbe inner tubes with Presta valves (SV4 for the Brompton) are delivered with a ring that also play the role of the adapter.
Quoted: 3459 Post(s)
Liked 1,465 Times
Agree with Jipe, you need the adapter.
I used to use the Wheels Manufacturing adapters, they are metal. But, I had some corrosion problems. I also had a tube fail near the valve stem which I blamed on the adapter. I no longer use them.
https://wheelsmfg.com/pss-1.html
I now use one by Mavic. This is the only place I know to buy, but there may be other places.
https://www.sjscycles.co.uk/rims-tap...der-to-presta/
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Palmer
Quoted: 1668 Post(s)
Liked 1,820 Times
Liked 1,465 Times
I put it on the valve stem, then insert the valve stem into the rim.
It had not occurred to me why the Schwalbe valve stem rings were shaped the way they are until I saw the post from TCS. But that makes sense and if you put the Mavic adapter on the valve stem first, then on most rims you could use that Schwalbe ring to hold the stem centered from the other side of the rim too.
Quoted: 840 Post(s)
Liked 336 Times
You put the Sunlite rubber grommet from the inside of the rim. After all, the main goal is to protect the tube.
Take a look at:
It's a video by Chris by Bike on You Tube. Very good Brompton channel. She knows her stuff.
In a response to one of the questions, she says to get plastic adapters for the schrader sized hole in the rim.
Good luck.
Good luck.
