Jandd rack: removing old powdercoat
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I have a rear pannier rack that's looking pretty shabby. The powder coating is flaking off, and I'd like to use it if I can get it cleaned up. I'm considering taking it to get media blasted and either keeping it silver or repainting it. Otoh, is there an easy'ish way to get the old coating off myself without marring up the aluminum real bad? If not, then I'll definitely repaint it. Maybe some tacky color to match the splash bar tape
Thanks!
Thanks!
Quoted: 18376 Post(s)
Liked 4,510 Times
Lots of internet notes suggest chemical strippers at home. Make sure whatever you choose is aluminum safe.
Sand blasting (your media of choice) gives a good finishing surface.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I've yet to call the place that does blasting, so I don't even know how much it'll cost. If it's cheap enough (prices on so many things have gone up), I'll probably just go ahead and do that. But, to satisfy curiosity in the meantime, here I ask
Liked 4,510 Times
I hadn't thought much about rack finishes. Are you sure it isn't anodized?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 4,510 Times
Paint will certainly flake.
I'm not sure powder flakes. Everything I've seen, it is like a heavy plastic, and remains slightly malleable, I think. So, it is more likely to scratch, or even surface dent.
For paint or powder, it may depend on the surface prep. Or, whether corrosion is able to get under the finish.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
I don't believe anodized flakes... at least not in the same way. It will wear. It should be imperceptibly thin.
Liked 4,510 Times
If it is anodized, you may be able to feather out any imperfections, then clean and paint.
Of course flaking could be a sign of some more serious issues.
Likes For CliffordK:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,799 Times
Anodization won't flake off. Stolen from the interwebs:
"Anodizing is an electrochemical process for producing controlled aluminum oxide films on aluminum. ... Unlike paint, which can flake off if not applied properly, anodized aluminum finishes are actually formed from the original material and cannot flake off."
Likes For gugie:
