I got TT brake levers for my bull horn bar. How should I route cables to look pretty?
Bikes: Koga Miyata Runner 1990
If you are looking for some cheap bar end brake lever, try one of those:
- ALHONGA HJ-R265A (30 $)
- Tektro TL720 (33 $)
Quoted: 722 Post(s)
Liked 353 Times
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
R200....drilling holes in your bars will not get you hammerdog's results because the cables exist from the top of your Soma levers.
You're better off buying a different set of levers. While your at it replace the old brake cables with some teflon coated ones.....
seems like maybe it could be internal routing, you can a see a hole in the bar end expander nut. I had dura ace tt levers that were like that. You had to tighten the nut first then fish the cable through it's center. Also ended up drilling an oval hole in the outside elbow of the closest bend for the cable to exit and run along the bars on the outside and under the tape.
Likes For jay4usc:
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
I have the same Langster model and liking the look
Quoted: 238 Post(s)
Liked 404 Times
I stopped riding the Langster for about 5yrs(no real reason) but decided to change it up a bit this Spring. Swapped out the drops for bull-horns and it's now my Go To bike for solo rides.
Such a simple change and glad I did it!......
Likes For Speedway2:
Quoted: 23 Post(s)
Omg lmao
OMG. The hole on top isn't for routing the brake cables. They route through the mounting bolt/nut in the middle, and internally through your handlebars. LOL SO DUMB!!!!!
