Uneven brake pads wear
Old 04-27-21, 11:26 AM
utoner34
Quoted: 46 Post(s)
Liked 4 Times in 4 Posts
I have mechanical disk breaks. My breaks work fine and this has never happened before. But I ended up with one break pads worn more towards one side (so it looks like a triangle looking from the top side). Meanwhile I removed them so I dont really remember what was their original position. I can just replace them with new pads but these (even worn out side) still has some more meat to loose. I am wondering in which direction should I turn my pads so that the pad which ended up with uneven wear now wears from the other side (which has more meat). Shoudl I turn them like in picture or the other way around?
utoner34 is offline
Old 04-27-21, 11:31 AM
wgscott
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,251 Times in 1,123 Posts
Brakes.
I would try to fix the problem rather than just rotate the pads, because right now you have sub-optimal braking, and it will likely be the same or worse if you rotate them (assuming they are symmetric and you can -- mine aren't).
The most likely problem is a stuck piston (left one stuck at the bottom). The second most likely problem is the rotor and/or caliper is mis-aligned.
wgscott is offline
Likes For wgscott:
Old 04-27-21, 02:15 PM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 347 Post(s)
Liked 351 Times in 234 Posts
No. you have mechanical disc brakes. The reply above explained what you need to check. It'd be easier to narrow it down further if you told us what brakes (calipers, specifically) you have.
Badger6 is offline
Old 04-27-21, 04:26 PM
utoner34
Quoted: 46 Post(s)
My brakes are TRP Spyre MD-C610C, Flat Mount (160/160)
utoner34 is offline
Old 04-27-21, 04:37 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 930 Post(s)
Liked 1,202 Times in 679 Posts
This thread should be in 'bicycle mechanics' not GD.
cxwrench is offline
Old 04-27-21, 05:00 PM
wgscott
Occam's Rotor
You aren't going to like this, but I finally sawed off my TRP calipers in frustration and replaced them with Shimano. But check what I suggested above before you do anything that drastic.
wgscott is offline
Old 04-27-21, 07:15 PM
veganbikes
Clark W. Griswold
Quoted: 2457 Post(s)
Liked 1,486 Times in 992 Posts
I don't have problems with Spyres they have worked well for me for years. I wonder if the rotor isn't true or the pads have been installed wrong? I do like the MSPaint instead of actual useful pictures of everything it is creative. Your local bike shop can take a look at it for you just remember they are BRAKES not "breaks"
veganbikes is offline
Old 04-27-21, 07:35 PM
cb400bill
Follow Your Arrow
cb400bill's Avatar
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR gravel Viscount Aerospace Pro
Quoted: 2507 Post(s)
Liked 3,267 Times in 1,987 Posts
Fixed typo in thread title and moved thread to Mechanics.
How did we get here?
cb400bill is offline
Old 04-29-21, 05:39 AM
Badger6
Badger6's Avatar
Quoted: 347 Post(s)
These are a dual piston design, meaning both pads are being moved by a piston, a bit easier to set up in my opinion.
Your rotors may not be true, but the wear your drawing depicts wouldn't be caused by that. It never hurts to check them, and if they aren't too buggered, get them straightened.
As stated a few replies up, it's either a stuck piston (dismount the caliper, and clean it and work it manually to get it moving smoothly again) or misaligned caliper (easily fixed by simply getting the bolts almost to the point where the caliper cannot be moved by hand, then pull the brake lever and tighten the mounting bolts so the caliper stays in place, then torque them down).
I think you should put on a new pad set as well.
Badger6 is offline
Old 04-29-21, 06:30 AM
utoner34
Quoted: 46 Post(s)
1. after you clean pistons with isopropyl alcohol, do you need to lube something in there?
2. I inserted new pads just to be clear to see whats happening.
both pistons are adjusted as far outwards as they can be (with the screws on the outside of the pistons)
here is the video:
you can see from the video that the left one is not vertically straight. right one is straight (more or less). Not sure if this is meant to be but with such behavior it seems to me that bottom of the pads are going to be more wear.
utoner34 is offline
Old 04-29-21, 08:22 AM
Crankycrank
Quoted: 466 Post(s)
Liked 341 Times in 271 Posts
Looks like time for an overhaul. A couple of tutorials here. PSA - TRP Spyre rebuild guide | Singletrack Magazine Forum (singletrackworld.com) .....
Crankycrank is offline
Likes For Crankycrank:
Old 04-29-21, 12:09 PM
utoner34
Quoted: 46 Post(s)
overhaul? I only have it for 6 months. I was under impression that this is a factory built intolerance. I dont remember honestly if this was present or not when the bike was new..
utoner34 is offline
Old 04-29-21, 03:27 PM
Crankycrank
Quoted: 466 Post(s)
Doesn't matter how long you've had it, it's not working properly now. Take it apart and see what's going on. Possibly this could be covered by warranty so check that out first.
Edit: When I said 'overhaul' it meant taking it apart for just a good clean and lube rather than having to replace parts which may or may not be needed.
Old 04-30-21, 12:04 AM
Badger6
Badger6's Avatar
Quoted: 347 Post(s)
Stuff can fail. 6 months sounds like a potential for warranty replacement (if the caliper can be had). What do you mean "factory intolerance?" I'd be shocked if TRP was selling a brake caliper that "intolerant." It's either dirty and needs to be cleaned, or something is damaged and it needs to be overhauled (and at 6 months age, sounds like a potential warranty issue...wait, I already said that...).
Badger6 is offline
Old 04-30-21, 06:42 AM
IPassGas
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 115 Post(s)
Liked 51 Times in 35 Posts
OMG!! I replaced my spyre pads recently and thought I cleaned it ok. But now that I've seen this, my cleaning was clearly superficial and I have a great urge to take the whole damn thing apart No doubt I will lose one of those ball bearings into the great parts wilderness that is my basement floor. That this person did it in woolen gloves is bewildering. Pardon my levity, thank you for showing this.
IPassGas is offline
