Which spokes for my wheel build?
Old 05-14-21, 01:05 PM
Chandne
Bikes: 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Yeti SB4.5, Pivot Shuttle
Quoted: 326 Post(s)
Liked 49 Times in 34 Posts
Any thoughts of the best spokes for my application- CX Rays, Race, some combo with heavier on the drive side? I'm a fast descender so wold like a slightly stiff wheel but also a comfy one for long rides. Two long-time builders say that while they use CX Rays often for clients, CX Rays build a slightly harsher wheel. I'm not sure either way but I have no reason to not believe them. I just want to know if there is a better option than using all CX Rays or DT Aerolites. I'm not after aero gains but I am after relative comfort and a good durable wheelset for fast twisty descents and long climbs.
Weight- 175 lbs
Bike- BMC SLR01
Rims- Easton R90 SL Rim Brake
Hubs- CK R45 (24x28)
Chandne is offline
Old 05-14-21, 02:04 PM
urbanknight
Over the hill
urbanknight's Avatar
Bikes: Specialized Allez Elite, Raleigh Pursuit tandem
Quoted: 145 Post(s)
Liked 171 Times in 108 Posts
It could be all psychological, but bladed spokes always feel "stiffer" to me. For comfort as well as durability though, I usually like to build with the super thin butted spokes (like Laser or Revolution) up front and NDS rear, and regular butted (like Race or Competition) on the DS rear to even out spoke tension.
It's like riding a bicycle
urbanknight is offline
Old 05-14-21, 02:08 PM
lukedunk
Bikes: 2017 Yeti SB5, 2017 Ridley X-Night
I've done a fair bit of reading, but am still a relatively novice wheelbuilder, so curious what others will chime in with.
From what I remember, you're not likely to get much difference in terms of "comfort" out of your spoke choice. Cross pattern may make a small difference to lateral stiffness, but any difference in vertical compliance is going to be insignificant compared with the tire and frame effects. I'm about your weight with similar use. My wheelset is Farsports shallow carbon rims, 24 front rear CX-ray laced to DT180s. Only complaint I have is occasional disc brake rub when powering out of corners, but that is hub flex, not lateral wheel flex. The wheels feel plenty stiff (and light!) for tons of climbing and descending miles. Hard to go wrong with CX-ray, IMHO.
lukedunk is offline
Likes For lukedunk:
Old 05-14-21, 02:10 PM
Chandne
Quoted: 326 Post(s)
I like that idea. That is basically what one builder was telling me. I just wasn't sure what combo to use for my weight.
Chandne is offline
Old 05-14-21, 02:21 PM
HTupolev
Quoted: 1788 Post(s)
Liked 962 Times in 474 Posts
That doesn't even out the tension. The reason that some builders use thinner spokes on the NDS is because they'll hypothetically hold up better at the low NDS tensions due to being more elastic (meaning that they'll be stretched farther, and thus have more margin from de-tensioning).
HTupolev is offline
Old 05-14-21, 03:14 PM
keithdunlop
keithdunlop's Avatar
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (main road bike), 2020 Soma Fog Cutter (gravel and daily commuter), 2021 Ibis Ripmo AF MTB build in progress
Quoted: 55 Post(s)
Liked 33 Times in 19 Posts
I've worked with both CX Ray and Laser spokes. I prefer CX Ray spokes because I can control the amount of twist-up better while building a wheel. I had a very hard time keeping Laser spokes untwisted even with using a spoke plier (they are very thin in the middle - 1.5mm). I just find bladed spokes easier to control in this respect.
That said, I'm riding a new pair of 35mm profile carbon wheels with Laser spokes (20/24). They just require a bit more experience to build in my opinion.
keithdunlop is offline
Likes For keithdunlop:
Old 05-14-21, 03:23 PM
urbanknight
Over the hill
Quoted: 145 Post(s)
You're right. I did a poor job of explaining it. It helps avoid any slack by a large imbalance of tension. I haven't played with any hubs wider than 135mm, but I'll bet that helps as well.
Old 05-14-21, 05:23 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1377 Post(s)
Liked 609 Times in 432 Posts
CX-Rays all the way. Best spokes in the business.
Kimmo is offline
Old 05-14-21, 05:48 PM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 328 Post(s)
Liked 119 Times in 86 Posts
I am going to keep this simple. I build wheels once in awhile and work on them. Just use a very good double butted spoke like DTSwiss. No need for bladed spokes or something fancy. Keep it simple and strong, yet nice. Use what is known and works well. To me your basic double butted spoke with proper tension and build will be strong and reliable. Now if you are building wheels for racing and how fast you can go then that is another situation............it comes with a different mindset.
deacon mark is offline
Old 05-14-21, 05:56 PM
Chandne
Quoted: 326 Post(s)
deacon mark: if double butted, which double butted spoke would you recommend for a 24x28 build and my 175 lbs?
Chandne is offline
Old 05-14-21, 07:52 PM
Symox
Bikes: '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 190 Post(s)
Liked 112 Times in 67 Posts
I use Sapim Race (double butted) along with their polyax brass nipples for my bike and am quite impressed
Don't know if there are any suspension benefits (absorbing road vibrations) - but they do feel great.
Symox is offline
Old 05-14-21, 08:12 PM
Chandne
Quoted: 326 Post(s)
Thanks! Seems like the Race and D-Light are pretty popular double butted spokes.
Chandne is offline
Old 05-15-21, 10:45 AM
deacon mark
Quoted: 328 Post(s)
Really I like DT Swiss Competition and Wheelsmith Spokes but I cannot seem to find Wheelsmiths anywhere did they go out of business?
Old 05-15-21, 08:42 PM
Chandne
Quoted: 326 Post(s)
Yeah, I think Wheelsmith spokes are no longer being made.
Chandne is offline
Old 05-15-21, 08:56 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3028 Post(s)
Liked 939 Times in 711 Posts
I now use CX-Rays on all my wheel builds - for myself. Costs more, but the build is so much easier and the wheels do seem a bit faster. I use them on my single, 20 X 24 and our tandem 36 X 36. These wheels stay at least as true as any IME and the spokes don't break. What's not to like? Oh - and besides they are flash.
Results matter
Carbonfiberboy is offline
Likes For Carbonfiberboy:
