Continental 5000
Old 06-25-21, 07:58 AM
nrsmd
Quoted: 29 Post(s)
Continental 5000
This tire claims less rolling resistance than the 4000. Is it wishful thinking that the same energy I put out for both tires will translate to a higher speed (MPH) with the 5000 than with the 4000? In other words, is it worth moving up to these tires if increasing speed is my goal?
nrsmd is offline
Old 06-25-21, 08:11 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 6064 Post(s)
Liked 3,224 Times in 1,863 Posts
Lower rolling resistance means less energy lost on tires rolling means faster speed.
Will you be able isolate the different and notice a few extra watts?...No idea. I cant, but maybe you are more in tune with your riding.
mstateglfr is offline
Old 06-25-21, 08:17 AM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a gravel bike…
Quoted: 381 Post(s)
Liked 744 Times in 319 Posts
Marginal gains add up if enough if them can be strung together simultaneously. 4000 to 5000 is not likely to put you on the podium, but the 5000 is a nice riding tire. I thought it had less road vibration than the 4000,but I think it could have been my imagination.
AdkMtnMonster is offline
Old 06-25-21, 08:27 AM
ClydeClydeson
Quoted: 299 Post(s)
Liked 437 Times in 264 Posts
If the 4000 absorbs 10 watts at certain conditions, and the 5000 absorbs 9 watts at the same conditions, Conti can honestly report that the new tires have 10% less resistance, but you only have a net gain of 1 watt - you'll get better gains with an aero seatpost or by tying your shift cable housings together in front of the frame..
Remember that rolling resistance is only a tiny piece of the total resistance to movement, and is relatively tinier the faster you go.
Wait until your GP4000s are worn out before you change.
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 06-25-21, 08:43 AM
Happy Feet
Happy Feet's Avatar
Quoted: 2156 Post(s)
Liked 1,236 Times in 670 Posts
+1 for the above.
I have GP 5000's. They replaced my 4000's when they wore out. I wouldn't switch one for the other before that. I just see it as the next gen of that series with whatever upgrade they've come up with in between but nothing earth shattering.
Happy Feet is offline
Likes For Happy Feet:
Old 06-25-21, 09:22 AM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 92 Post(s)
Liked 98 Times in 69 Posts
From my extensive review of the literature, the marginal gains using optimum tire pressure, rolling resistance and aero rims, might, in ideal situations, get me to first in line at the rest stop porta-john. But if my rain jacket flaps too much, I'll have to find a tree.
It's getting kind of ridiculous for recreational riders, don't ya think?
bblair is offline
Likes For bblair:
Old 06-25-21, 09:34 AM
pickysoul
pickysoul's Avatar
GP 5000 gets puncture easilier than 4000. try Pirelli Pzero,dude.
pickysoul is offline
Old 06-25-21, 10:40 AM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91, '78 Raleigh Competition GS
Quoted: 3237 Post(s)
Liked 1,831 Times in 1,299 Posts
Does Continental even make the 4000 any more? If you still find them, they are just NOS.
If you stock up on old stock, then you'll be living in the past longer when even better tires come out.
Iride01 is offline
Old 06-25-21, 11:04 AM
shelbyfv
shelbyfv's Avatar
Quoted: 2569 Post(s)
Liked 2,824 Times in 1,509 Posts
That's good to know, I was unaware. The 5000s seem true to size while the 4000s were often larger than nominal. Other than that, I can't tell a difference. Nice tires, both.
shelbyfv is offline
Likes For shelbyfv:
Old 06-25-21, 11:11 AM
AdkMtnMonster
Quoted: 381 Post(s)
That’s laughablier untruly.
i have nearly 10k miles on a front GP5000 with zero flats, and I rode a rear all the way down to the cords last year with only one punch flat, which was 100% MY fault for nailing a smallish pothole @ ~54mph. 5000s are TOUGH meats that ride great.
Likes For AdkMtnMonster:
Old 06-25-21, 11:22 AM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 937 Post(s)
Liked 767 Times in 423 Posts
Very little difference in puncture resistance between these models, per bicyclerollingresistance.com:
Tire model - rolling resistance - puncture score
PIrelli P Zero Velo - 13.2 - 54
Continental Grand Prix 5000 - 10.7 - 49
Continental Grand Prix 4000S II - 12.9 - 52
Ride, Rest, Repeat
terrymorse is offline
Likes For terrymorse:
Old 06-25-21, 11:55 AM
msu2001la
msu2001la's Avatar
Quoted: 616 Post(s)
Liked 519 Times in 314 Posts
It's 1000 better.
msu2001la is offline
Old 06-25-21, 12:01 PM
icemilkcoffee
Quoted: 445 Post(s)
Liked 317 Times in 196 Posts
FWIW I always have trouble mounting 5000's on every rim I've tried. The 4000s II is noticeably easier to mount.
icemilkcoffee is offline
Old 06-25-21, 12:38 PM
Barry2
LR÷P=HR
Bikes: 79 Holdsworth Special, 93 C-dale MT3000 Tandem, 96 C-dale F700CAD3, 2018 Cervelo R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 388 Post(s)
Liked 392 Times in 247 Posts
+1
5000's are t.i.g.h.t !!!!!
As per other thread, Parachute Cord is your friend
Barry
Barry2 is offline
Old 06-25-21, 12:45 PM
Iride01
Iride01's Avatar
Tubeless or tubed version of 5000's are harder to mount?
I've no experience with the tubeless version, but the tubed version of the GP 5000 are some of the easiest to mount or remove. No levers needed.
There is only room in the spoke channel for one tire bead. So make sure you push the bead of the already installed side out of the spoke channel as you push the other into it.
Iride01 is offline
Likes For Iride01:
Old 06-25-21, 12:51 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 601 Post(s)
Liked 145 Times in 114 Posts
4000's in the 700x25c size are noticeably larger than a 5000. I learned that because with 4000's there is very little clearance between my fork and tire but with the 5000 there is several mm's more clearance. That may be a contributor to the 4000's having more rolling resistance.
Nessism is offline
Old 06-25-21, 12:54 PM
Tomm Willians
Tomm Willians's Avatar
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 188 Post(s)
Liked 434 Times in 142 Posts
Keep in mind that saying one tire is more puncture resistant than the other is just a consideration. I’ve run GP5000’s on three different bikes for two years with zero flats. While I’ve no doubt the 4000 is more resistant, the 5000 has proven itself good enough in that category. At least on the routes I ride.
Tomm Willians is offline
Likes For Tomm Willians:
Old 06-25-21, 02:01 PM
Jrasero
Bikes: Canyon Ultimate CF SL Disc 8.0
Quoted: 62 Post(s)
Liked 38 Times in 28 Posts
While I can contest that GP5000 are awesome tires, they aren't worth upgrading if your GP4000 are in good shape since a set of GP5000 aren't cheap
Jrasero is offline
Old 06-25-21, 02:42 PM
MrWasabi
MrWasabi's Avatar
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 123 Post(s)
Liked 49 Times in 34 Posts
How are the GP5000s on less then perfect pavement and hardpack?
MrWasabi is offline
Old 06-25-21, 02:53 PM
Hiro11
Bikes: To the right: opinions, not facts.
Quoted: 663 Post(s)
Liked 305 Times in 165 Posts
To answer the OPs question: no, it's not worth it. When your tires wear out,just buy the 5000s then.
Personally, I'm currently on my second set of 28mm GP5000TLs. I weigh about 165 and I run them tubeless on hooked carbon rims at about 75psi in the front and 77psi in the back. Despite their reputation for tightness, I can mount them on these rims with my hands. I got at least 4.5k miles on the first set with no punctures (none at least that I noticed). I probably threw out the first set a bit early to be honest. The second set is going strong at 4K miles on our terrible Illinois roads. Incredible tires in all respects: grip, ride, speed, reliability, durability. I have another set in storage already for when these wear out. I'm sure other tires are also great, but why mess with what works.
Hiro11 is offline
Old 06-25-21, 06:38 PM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 545 Post(s)
Liked 192 Times in 132 Posts
I just mounted a pair on Roval SLX 24 wheels last weekend with no issues. No tools needed to get them on.
dmanthree is offline
Old 06-25-21, 10:22 PM
rsbob
Sniveling Weasel
Bikes: Orbea Orca, Fondriest Racing, Bianchi Trofeo, Bianchi Infinito, Schwinn Varsity, Trek mtn
Quoted: 530 Post(s)
Liked 790 Times in 499 Posts
I have Conti 5000 tubed on one bike and tubeless on the other. Neither are any more difficult to mount than any other Conti tire. A couple of tire levers and you should be good. My tubeless are as easy as tubed but it could be my rims too.
Rick S
“He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche. “An argument based reasoned fact, beats one based on emotional rantings every time” Anon
rsbob is offline
Old 06-26-21, 02:55 AM
ooga-booga
lead on, macduff!
ooga-booga's Avatar
Quoted: 1118 Post(s)
Liked 1,499 Times in 825 Posts
was avoiding riding on hard-packed gravel/dirt with the conti gp 5k's originally with the first pair. since then, they've been slapped on all four road bikes,
dirt is fair game. pavement in metro san diego is hit or miss. either pretty dayum smooth or why hasn't this repaved in a decade?!
tires have held up well w/o issues or flats while riding tubed. maybe i'm just lucky x 4...
ooga-booga is offline
Likes For ooga-booga:
Old 06-26-21, 05:33 AM
MrWasabi
MrWasabi's Avatar
Quoted: 123 Post(s)
Thanks for the input. I'll be running mine with tubes on mostly paved MUPs/trails and some FL hardpack.
MrWasabi is offline
Old 06-26-21, 04:42 PM
Troul
:D
Troul's Avatar
Liked 1,089 Times in 781 Posts
I have yet to go 4,000 miles without a flat on the c4k, I highly doubt I could go 5,000 miles before a flat when using the c5k tires.
-Oh Hey!
Troul is offline
