Go Back  Bike Forums > The Lounge > Blogger's Forum
GMC Denali Phase I
Blogger's Forum Whether it's a cycling blog, or just your personal page, this is the place to share ideas and links.
GMC Denali Phase I
Old 07-15-21, 01:45 PM
grizzly907la
Grouchy Old man
grizzly907la's Avatar
Bikes: Diamond Back Insight 2, Gravity Basecamp mountain bike, GMC Denali Road Bike
Quoted: 75 Post(s)
Liked 49 Times in 36 Posts
GMC Denali Phase I
I finally rebuilt the GMC Denali Road bike I got roughly two weeks ago. It didn't go exactly the way I planned it. I want to go with drop bars and brifters, but decided against that and instead went with flat bars. I had to send back the hollowtech bottom bracket, because the non drive side crank arm had a stripped bolt and the large chainring was warped. Opted for a sealed bb instead and some cranks I cannibalized from another bike. I am keeping the stock fork for now, and used the wheelset from the bike I cannibalized. I used the savings I got for the returned BB and purchased some 28c tires, along with innertubes.
A bike is just a frame, with components on it. The Denali is perfectly ridable with the stock parts. Of course they are not the best and require some TLC, however it's ridable after assembling it and and adjusting the components. The Kent/Denali road bike an inexpensive option for a commuter or casual rider. Components can be upgraded over time thus defraying the costs.
Phase I is complete. I want to do upgrade the fork to a lighter fork, go with a threadless headset, and install a hollowtech bb. Will post updates as they come.
grizzly907la is offline
Likes For grizzly907la:
Old 07-18-21, 02:43 PM
Maelochs
Maelochs's Avatar
Quoted: 6324 Post(s)
Liked 1,277 Times in 730 Posts
Following this project with interest.
I'd check with Walmart if you can get replacement decals, in case you do want to strip the frame.
I grin just imagining the reactions of "serious" cyclists if I rolled up on a Denali.
One question I do have concerns tire clearance. You aren't doing much real gravel with anything less than 38s. Do you have room in the back?
Maelochs is offline
Old 07-18-21, 04:30 PM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Quoted: 159 Post(s)
Liked 63 Times in 48 Posts
These have 38s stock.
Jax Rhapsody is offline
Old 07-18-21, 07:06 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
"Serious," cyclists would probably turn their noses up at it. I doubt that Walmart has replacement decals. I would print out replacement decals if I had access to Cricut printer. I kept the GMC decal on it, just for s**ts and giggles. I don't know if 38'S will fit, but I do know that 32's will in fact fit. Ironically enough I have 38's on my Diamond back Insight II.
Old 07-18-21, 07:14 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
I am using the following components for this bike.
1. Wake drop bar...very wide drop bar.
2. Shimano Rapid fire shifters
3. Tektro Brake levers.
4. Ergonomic grips.
5. Generic steel crank
6. 68x122.5 bb
7. Shimano 105 front and rear derailleurs.
8. Alex Rims
9. 700x28c Continental ultra sport II tires.
10. Fooker pedals.
11. OEM Steel fork.
12. OEM Threaded headset.
11. Profile design threaded handlebar adapter.
