Which Sturmey Archer hub?
I'm currently rebuilding an old French cyclotouriste / porteur bike and would like to set it up with a hub gear.
https://www.bikeforums.net/showthread...ighlight=vitex
I was initially thinking about an old AM hub as the closer ratios should be good for London cycling - it's mostly fairly flat where I ride. I don't need a wide range of gears but want a bit more versatility than I'd get from a singlespeed. I've found a couple of sources for reconditioned hubs. I know from experience that the older SA hubs are more reliable than those made in the 70s/80s and the only issues would be finding a suitable 40H rim, and the dropout spacing (118mm), which would likely need a couple of washers.
However, I've been hearing good things about modern SA hubs and that's got me thinking. A 36H hub would open up a wider range of rims and if a newer hub offers better performance and equal reliability, that's probably the way to go.
What are people's experiences? Any recommendations for a medium/close ratio modern hub? Or should I stick with plan A and get an AM?
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 65 Post(s)
Liked 304 Times
If you can find an AM hub, the innards will fit in an 36 hole AW shell, so that negates the need for a 40 hole rim.
The only real drawback to the AM is that certain parts, such as the gear ring, are specific to it and quite rare. That said, a 50 year old AM should be good for another 50.
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
What size rims are you planning on using? I'd keep the AM shell even if it was 40 holes. Part of the joy of having a AM hub is letting others know you have an AM hub and not have it disguised inside the more common AW hub. There are plenty of rims with 40 holes if you are going 700c. I've even found 40 hole 27 inch rims. Good luck
Quoted: 380 Post(s)
Liked 106 Times
As a 15 year old in 1964 I had to regularly replace planet gears in an AW hub from just riding it off road. Maybe two or three a year. That will be the part that breaks. Would not be my choice especially at the weights you are talking about. Roger
From the parts diagram, https://www.users.globalnet.co.uk/~hadland/sa/saam.pdf for the AM, I think you are going to have a hard time making the axle fit in a 118 frame. The AW had 2 axles a 5 3/4 & 6 1/4. The 6 1/4 was used for 120 spacing. It looks like the AM only has a 5 3/4. It is a different part number than the AW axle, so I'm not sure you could replace the axle with a AW one. You could cold set your from down to 110.
I'm actually looking at having an AM hub built from NOS parts. It will be fitted inside a used hub shell, and my supplier may not be able to find an original AM shell - so it will be no great tragedy if an AW shell is used. Rims will be either 650A or 650B. 40H rims are not impossible but I'm yet to find a local supplier, and also finding a matching 36H rim for the front may prove tricky. If he can turn up an original AM shell I will use 40H rims.
I will ask my source if he's able to build one with a 6 1/4" axle. 5 3/4" will be very tight, leaving perhaps 3/8" of thread on each side...
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Thanks!
Thanks Roger, interesting stuff. Although this bike will not regularly be heavily laden. I don't plan on using it for serious loaded touring. I weigh around 150lbs, and the bike itself will be relatively lightweight and mainly used on fairly flat roads. It's not going to work that hard - although I do enjoy riding fast. What would you suggest as a more rugged option. Would newer SA hubs be any better, or how about an SRAM P3?
Narrow and medium range hubs intended for sports riders ceased production when the derailleur started taking over from the geared hub on sports bikes in GB, basicallly in the late 50s to the 1960s or so per my understanding. Sachs market was always utility bikes so far as I know so they never made any narrow or medium range hubs that I am aware of.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Re. the 40H rim... you can lace a 40H hub to a 32H rim.
word.
I think this may be relevant to your interests.
https://yacf.co.uk/forum/index.php?topic=17531.msg314519
Also, S/A is making (going to make) a nice thumb/downtube and bar end shifter.
https://www.sturmey-archer.com/produc...rs/cid/3/id/10
https://www.sturmey-archer.com/produc...rs/cid/3/id/11
Gabe
Gabe
Gabe
Gabe
word.
The new S/A AW and S-RF3(alloy shell AW) have revised internals. The clutch design has been improved, and they should not have the 'between gear' positions. I've build a few wheels using the new alloy 3 speed and it works well. The flanges are nice and thick. It does not seem to slip in high gear, as some of my older hubs will do under very heavy load. I run most of my A/W equipped bicycles (26x1-3/8 tire) with a 22T cog and a 46T chainring. In relatively flat Florida, this provides a good mix of gears, especially when facing a headwind carrying a load of groceries up a slight grade.
https://www.sturmey-archer.com/userfi..._Speed_Hub.pdf
Quoted: 443 Post(s)
Liked 27 Times
I built a bike around an S-RF3 and I love it. There is no neutral position. There is no oil seepage. Spoke washers are not necessary.
I just finished building a wheel with a SA5-2. I found that it was necessary to use double spoke washers with DT Competition spokes. I haven't tried it yet because the frame is waiting for paint.
Palmer
Quoted: 1667 Post(s)
Liked 1,820 Times
The 26 x 1 3/8 (ISO590) Sun CR-18 rim is available in 32, 36 and 40 spoke hole versions.
The dual-indicator-chains Sturmey S5 hubs can be nice.
For an inexpensive, narrow OLD, close ratio hub, try the modern Sturmey-Archer XRF8(W).
tcs
tcs
I think it's between the S-RF3, the AW and an AM. I'll decide later.
Palmer
Liked 1,820 Times
tcs
No, not necessarily. I appreciate your suggestion, and must admit I hadn't looked carefully at the ratios. I will be keeping my eyes open for a used S5 and if one turns up at the right price I'll consider it. How are they in terms of reliability, shifting, false neutrals etc?
Been reading Sheldon's servicing article on the S5. He suggests:
- For the right side cable, it's best to use a standard 3-speed trigger, cable and indicator spindle.
- For the left side cable, it's best to use a friction-type derailer shifter of some sort. There are only two positions, tight and loose, so there's no need for any sort of "indexing" on the left cable. It is also possible to use two of the positions of a three-speed trigger for the left cable, but adjustment becomes rather finicky.
- The right lever or trigger selects underdrive, direct drive or overdrive, just as with the AW and other 3-speed models.
- The left lever selects between narrow range 3-speed and wide range 3-speed. When the cable is loose, it's narrow range; when the left cable is tight, it's wide range.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Also just to throw some more confusion into the discussion...you can convert the FW/FG hubs to 5 speed, they will work just like the S5. Using the standard 3 speed click shifter and a friction on the left side. I haven't done the conversion myself, but know a couple of people that have. I have an FG that is going to get the conversion because it doesn't have the 2 part indicator rod and they are hard to find and expensive when you do.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Quoted: 443 Post(s)
Liked 27 Times
My S5 came from the UK. It was expensive, but I wanted it badly. I think I paid just around 60 British Pounds for it, plus shipping. It's from 1982, but it shows no signs of use. I have the original stem shifters, but I think I'll use a trigger shifter on the right and a Suntour ratcheting thumb shifter on the left.
I got mine at Aebike about 3 years ago. Any shop that can order from QBP can get it. The price has gone up quite a bit, unfortunately. I didn't like the shifter that came with it so I'm using a vintage trigger shifter.
