FD-6500 - Should Cable Contact Derailleur Body
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
I replaced the OEM BB last summer with another of the same proportions. I think that the original was Ultegra and the replacement was 105. I'll see if I can find the OEM BB in my parts bin to verify the width.
If I did have a triple BB in there, and that would push the crank outboard as you say, would that not reduce the likelihood of contact rather than increase it?
Next question: how strong is the FD return spring? I understand your description of the problem but am having a difficult time understanding why such a mild force - the Bow Effect, as you put it- would be able to move the FD in any amount at all when presented with the force of a healthy return spring.
Additionally, have you considered putting a little more slack in the cable when the lever is in its fully depressed position? No harm to be had there, and it would remove any potential Bow Effect.
So the OEM and current bottom brackets are both 109.5 mm wide. I tried to snap a pic on my way out the door for work but my phone died just then.
Likes For Harold74:
I don't really know how to answer that. I don't know how stiff it is or how stiff it out to be I'm afraid. I'll man handle a few derailleurs when I get home tonight to see if I can get a sense for whether or not the spring in question has gone soft somehow. As you know, springs are freakishly reliable. Just not a lot to go wrong there.
I see your point and sympathize. Anecdotally, I identified the problem -- as I've described it at least -- while riding. Simply put:
1) When there is no contact, the FD lever and FD stay put.
2) When there is contact, the FD lever and FD move to eliminate the contact.
This is what led me to the "bow theory". I am open to the possibility that my theory may be incorrect however.
It has been my experience with downtube, bar end, and thumb shifters of many kinds that the forces at play are actually in a pretty tight balance. That's the only way to produce "light action", right? This is so much the case that all of the shifters in my possession seem to offer differing amounts of resistance to motion with the spring vs against the spring.
I hadn't considered that but I will, now, at your recommendation. I might struggle to love it though as I'm pretty into having my cables taught. It certainly would seem to solve the problem if the bow theory is what's actually happening. A slack cable makes for a pretty lousy bow. I already find my rear brake cable slackness annoying but livable so perhaps I can adapt.
I've been doing the thing where I fasten the cable with a 3rd hand tool and then dial up the limit screw to deliberately get the cable taught. Maybe that's the source of the problem.
Quoted: 3490 Post(s)
Liked 2,909 Times
Likes For smd4:
It's a common trick for getting the appropriate cable tension into the system for modern brifter setups, no? This was the only way I could get my wife's Tiagra 10sp setup to shift properly up front.
aka: Dr. Cannondale
Liked 3,401 Times
Well, it’s one way to do it when working with STI’s, which have limited pull variability. When you move ‘em, they click. But friction downtube shifters have bunches of pull variability, so no need for the cable to be any tighter than pulling it taught by hand when the lever is in the low position.
Liked 2,909 Times
Ah. I was thinking of downtube shifters, and adjusting cable tension (and limit screws) as described by rccardr.
Realistically, if there were a ton of pre-tension in the FD cable, it would just move the FD to relieve it, right?
Liked 2,909 Times
Sure, except doing so will alter the shifting precision, and possibly make the derailleur inoperable. Personally, I only use the limit screws to adjust derailleur travel. I've never used integrated shifters, so I don't know how they're adjusted. But with downtube shifters, after setting the limit screws, then I'd adjust the cable tension using the method rrcardr described earlier (although I'd use needle nose pliers to get a better grip on the cable). And so, in my method, there is no "pre-tension." With the derailleur on the small ring, shift lever all the way forward, I pull the cable taut and snug the binder bolt.
Alright, I'll give the cable slackening thing a try. Thanks for your help gentlemen.
By coincidence, I did a pre-purchase inspection on a 2002 Lemond Zurich over the weekend. It's got the very same derailleur. And the cable contacts the dust cap thing in the same way. The photo below doesn't show it well but there's a black track mark on the dust cap where the cable touches. This bike is a brifter setup with a fairly taught cable and no discernable ghost shifting problem. This new information doesn't really change anything discussed here. Just another data point for interest's sake.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
4700 tiagra??? next time, set the Tiagra Ft. Der. with the Tiagra Brifter in the SECOND Click position.... as per Shimano. I own a 4700 Tiagra group... the full instructions are online....
I just bought a Lemond Zurich with this same group set and can confirm that the FD shifts flawlessly with the matching Ultegra brifter.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,454 Times
Expired Member
Quoted: 3654 Post(s)
Liked 5,391 Times
Good to know there is no design flaw inherent in the FD.
aka: Dr. Cannondale
Liked 3,401 Times
Please explain the difference in cable routing for STI vs. Down tube shifters once it hits the BB. I’m…intrigued.
Likes For rccardr:
Ultegra Brifters
Downtube Shifters
Liked 2,909 Times
Obviously, where the bare cables encounter the bottom bracket guides, there's is no discernable difference in routing.
Both nice bikes, BTW.
Thanks for that. The blue and white Lemond Zurich is new and is something of an experiment in fit. The titanium frame is interesting in that it is both compact and uncommonly long in the effective top tube relative to its other dimensions. As you can see, I had to jump through some hoops to get the fit right for me on the front end. But, now, it fits like a glove. As the two bikes are currently set up, they are of identical size with respect to the relative location of my body/bike interfaces (bars, bottom bracket, seat). I'm hoping that the Zurich can be an equally comfortable ride as the titanium bike but with more conventional proportions. My seat post is probably a little short on the Zurich but that just seems to be the required compromise for me to be able to achieve my preferred reach and stack height. Long arms.
Liked 2,909 Times
Liked 739 Times
Heads up... watch for Cracks around the spoke holes in those Bontrager Racelites...
aka: Dr. Cannondale
Liked 3,401 Times
If both bikes use the same FD and there's a difference in cable clearance between them, it's due to the difference in BB cable route spacing, not shifter type.
Quoted: 1607 Post(s)
Liked 2,213 Times
Nice bikes. Looks like the LeMond might be a better fit, IMHO. The TI looks too small.
Likes For SJX426:
