Wheel Tension Question
What is the target for rear drive side tension on a rim? Rim is 115 kgf max, I am at about 90 and close to true. Work the drive side up and then just balance out NDS? Been a while since I have done this!
Quoted: 4192 Post(s)
Liked 3,837 Times
Butted spokes? How many spokes?
Your process is much what I do. Over dish with NDS tension lagging while DS is ramped up and trueness and spoke tension evenness is maintained. As DS tension approaches target range the NDS spokes are used for dishing and trueness. Easy to say but kind of like dancing between the two sides when one is favored early on and the other catches up. Andy
AndrewRStewart
AndrewRStewart
Quoted: 4337 Post(s)
Liked 1,521 Times
I build in dish and tension in dish. It's easier , and probably easier on the components. It also reveals problems earlier.
The more spokes, the lower the individual tension. The tension needed to support a run with 24 spokes could destroy the same rim with 36. For 32 I would be aiming for mid range.
Likes For Kontact:
Quoted: 5762 Post(s)
Liked 2,534 Times
The rim is rated by the maker at 115kgf, so unless you have the expertise to override that, I'd respect it.
I also like to leave room, so I'd target 100kgf or so.
When building, I prefer to bring a wheel to true, (spot on for radial, less than perfect for wobble) slightly over dished at 5-10% shy of my target right side tension.
Then I work the NDS spokes only to dial in the dish, and final true. This also adds the last few points of tension, and spares me having to work with highly tensioned spokes.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
aged to perfection
Quoted: 829 Post(s)
Liked 1,240 Times
if it is acceptably true at 90KGF I would suggest you stop there.
/markp
/markp
Quoted: 2593 Post(s)
Liked 1,922 Times
aged to perfection
Quoted: 829 Post(s)
Liked 1,240 Times
well you have to do what's right for you.
An absolute measurement is not something I personally would resort to in the case of spoke tension. Every rim / spoke combo is different.
A modern DT rim will take tensions in the 125 kgf range. A vintage Superchamp rim, probably less.
Also the spokes will vary across a range of tensions in a properly built wheel. Even a very skilled builder cannot get them all exactly the same. The trick is getting them in a narrow range.
and remember the spokes see load excursions as the bike is ridden, hits bumps, etc.
counterintuitively the spoke tension is reduced as the tire is inflated. At least on clincher wheels.
And then of course how accurate is your instrumentation. if you're using a rock to measure spoke tension, allow for some uncertainty. Leave a safety margin.
but what do I know?
/markp
but what do I know?
/markp
Really Old Senior Member
Get a copy of Spocalc.
Plug in your hub dimensions.
It'll give a % 0f L/R.
See how much R you need to get a minimum of 65kgf on L.
IF you can't get 65kgf without exceeding your max, then use a locking nipple on the L.
Usage will play into this too. Skinny person on smooth pavement w/ no potholes or a huge clyde doing "stunt" biking?
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Insisting on an arbitrary minimum NDS tension of 65 kgf would put the DS spokes of many of my rear wheels over the rated max. Thankfully, I have yet to find that necessary.
Likes For ThermionicScott:
Liked 2,534 Times
As mentioned earlier, we often need to target DS tension based on the minimum acceptable tension on the NDS.
That minimum tension depends on a variety of considerations, including: spoke gauge, rim rigidity, number of holes, rider weight, riding style, etc.
The key, is to target tensions for the best balance based on ALL the factors. Often we cannot satisfy all considerations, so then we seek the best compromise.
On modern high dish wheels, I generally do best with thinner spokes, especially on the left. While many follow the trend of working with very high tensions, I stay with the more moderate tensions that have served me well for half a centuty.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,563 Times
Thanks everyone, each piece of advice helped indeed. It came together pretty well. I have pretty even tensions on both sides.
Likes For etherhuffer:
