last rides before ice
Quoted: 5224 Post(s)
Liked 3,581 Times
One of my Ice Spiker Pro tires has a folding bead BUT its also tubeless ready which negates the folding being easier to mount thing.
Likes For gecho:
A side benefit of switching to my Edge 800 is accurate gps traces. I can't believe how much worse the accuracy is of current generation Garmins compared to one 3 generations old. I'll do multiple loops of a fat bike trail where each pass is within inches of each other and my Edge 830 will have differences of a dozen meters in position.
The responsiveness of the old 800 touch screen is much better than the new ones too. No having to swipe 5 times to change screens.
Liked 3,581 Times
1st ice
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
Winter conditions have been slow in coming in the Twin Cities metro. We had one icy weekend and then a return to dry conditions. We've had some moderate cold, but even that is backing off. It's supposed to get up to 50°F on Wednesday. Based on the forecast, we should still be on road bikes for at least another week. Unusual luck.
Likes For MinnMan:
Breaking that kind of ice is satisfying, but you need to do it with caution. After you break through, the ice pushes against both sides of the rim affecting handling. If the ice is somewhat thick your wheel will be locked into the channel and won't be able to steer which can throw out your balance. Basically you are in a rut the exact width of your wheel.
Likes For gecho:
Its been warm enough the past week that the roads are wet every day. But not warm enough to melt the roads down to the point that I'd want to go without studded tires. Even the side streets are in good condition, mostly just stud friendly packed snow / ice no loose snow, ruts or brown sugar.
Pretty much back to starting from zero for the fat bike trails we groomed. What hasn't melted completely is glazed and icy. We might see the last of the above freezing days starting this weekend along with some fresh snow.
Likes For gecho:
Side streets are just starting to shift towards the kind of glossy ice that is more of a challenge for studs. Also getting more rut channels worn mostly to the pavement. I caught the edge of one of those in March after it was hidden by fresh snow and wiped out at a pretty good clip.
One annoying thing about riding with studs on clear pavement is that you don't want to be cornering aggressively with them. So I still do the kind of awkward lean body while keeping the bike upright turning, which requires going slower.
Mud sprayed all over the bike so I had to do a clean and relube again. I use one of those hand pump chemical sprayers filled with hot water to spray off the bike outside.
Likes For gecho:
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
Oh man .... I can think of many early winter rides relearning this! Lean into a turn summer-style, bike gets squirrelly, pucker up, and with a little luck ride outta it
Likes For Hypno Toad:
Liked 3,016 Times
The ice made a dramatic reentrance overnight in the Twin Cities. A small amount of snow falling right around freezing - everywhere the cars compacted it, it became glare ice. I didn't have the presence of mind to take photographs. I also didn't anticipate that the small snowfall would create such icy conditions, and so the studs were not yet on. Did OK anyway on 43 mm Terravail Cannoballs at about 32 psi. Wide tires at low pressure are surprisingly sure-footed even on fairly serious ice. BUT definitely would have been happier with studded tires. They are mounted now, as it looks like the ice will stick around.
I had a nice metric century group ride on road bikes Saturday. I'm glad we got that in before the road bike season ended.
Likes For MinnMan:
Liked 3,581 Times
First taste of miserable cold with temperature dropping through out the day. Was -16C around noon with strong winds, with it falling to -25C tonight. Tomorrow its getting up to -15C and the wind will be lighter so I should make an effort to get out as I haven't been out in that temperature yet this season.
I did some additional testing on my DIY heated gloves. On high they will get to 185F, but low and medium provided much more usable temperatures. I put together a pair of new controllers which will give me more control over the temperature using a dial instead just 3 settings.
Likes For gecho:
meh
Liked 1,013 Times
Wet snow this morning and a high temp of 14°F tomorrow .... It's time
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
I'll tough out the skipping and give it a go this afternoon. That 14F is looking optimistic at the moment. The current is to not make it out of the single digits. I will have to go look at my clothing chart to see what might work.
Likes For MNBikeCommuter:
Liked 3,016 Times
Likes For MinnMan:
Quoted: 92 Post(s)
Liked 109 Times
I think the politically correct term these days is "feels like" temperature. They said the wind is supposed to die down a little this afternoon but I don't think I'll notice a difference from the estimated 17 mph and the current 20 mph. It's at least more sheltered around here than out on the open prairie of western ND where I grew up.
meh
Liked 1,013 Times
OK, we will not see 14°F .... or maybe we did it at midnight, and it's been sliding towards 0 all day. Today's ride, per Garmin. And on topic, SO SO SO HAPPY I mounted the studs yesterday!
Liked 3,581 Times
My commute in Minneapolis this morning was at, I think, 8°F. Fortunately, it's a short commute (less than 2 miles). I had the bar mitts on, but it still hurt for the stretch directly into that 20 mph wind. (What's that thing they call "wind chill" at 8 °F air temperature and 20 mph wind?)
Liked 3,581 Times
dry nite. got the road bike out on a regular route. interesting riding in the city for a change. the aromas & sounds, wood fires & food cooking, Christmas music playing in the distance & even holiday church bells ...!
Likes For rumrunn6:
Liked 3,581 Times
tik toc, time is running out! once this trail gets snow it turns to ice & the pavement isn't clear again until late March. BFRT Acton - Chelmsford
good for 20 miles at 43 degrees
