Detecting major left/right power imbalance with just a smart trainer?
I have had herniated discs in the neck with associated loss of strength in my left arm due to the disc pinching a nerve. I went from pressing a 32kg kettlebell to not being able to press a 16kg bell overnight. This has happened twice. Strength mostly came back each time, but my left arm kettlebell press is probably 95% of my right arm (which is probably within the norm. Most people are stronger on one side. The right is my dominant side, as well.) The herniated discs is still there and from time to time flares up but I do some neck stretches (McKenzie Technique) have mostly eliminated the pinched nerve and further loss of strength.
I've also had aggravated discs in my lower back after deadlifting heavier than I needed to. But I've never noticed nerve pain in the leg or loss of strength. Back currently feels fine. It's my understanding that the nerves that control the leg are in the lower back.
In the last few months, I've felt, going up stairs, that my left leg wasn't firing exactly right. Just a little bit of pain in the outside quad.
Two weeks ago I started biking again after a really long layoff. I've got a Tacx Vortex that shows power, but not for the individual sides. Left side doesn't feel quite right - but I freely admit it could all be in my head.
A dual sided power meter is not in my immediate future, but I'd like to test the power imbalance to at least put my mind at ease and to know my disappointing ramp test was due to being out of shape and not due to a nerve issue in the leg.
I was thinking about a 1 or 5 min test with each leg? Would that work? What's the range of a 'normal' imbalance? (I listened to the TrainerRoad podcast where the speakers recommended not worrying about imbalances. They mentioned an Olympian with an greater than 8% imbalance that only got injured when he/she tried to fix it. I'm just hoping mine doesn't show something much greater than that.)
Any other ideas?
Any other ideas?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
I don't have an answer to your main question, but my experience about imbalances (based on 2-sided PM pedals) is that for a very long time, I seldom saw anything outside of 48/52 or 52/48. More recently, dealing with injuries, I can have rides as disparate as 55-57/45-43, but not for all rides- most are better balanced. (oddly, one of my bikes seems to lend itself to the more imbalanced values, and I haven't figured out why - same pedals, shoes, crank lengths - must be a slightly different saddle position that incites it).
(Is 48/52 a 2% imbalance? Or is it a 4% imbalance? Or is it an 8% imbalance? (52/48= 1.08).
Quoted: 20810 Post(s)
Liked 9,456 Times
Visit a physical therapist?
If you're trying to do one-leg drills to test imbalance, I think it's more likely that you'll be seeing differences in coordination rather than strength; one-leg drills are generally a pain in the ass, but I'm certainly much better on one side vs the other (I forget which), and I don't believe that I have any significant power imbalance.
Likes For WhyFi:
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,860 Times
Chronically denervated muscles should show atrophy and fasciculations, (small twitchy movements at rest). If you're concerned ask your doc to refer you for electromyography and nerve conduction studies. That information is definitive.
Likes For MoAlpha:
Quoted: 18883 Post(s)
Liked 10,646 Times
I don't think you'll be able to tell without dual pedals. But I think there are stationary bikes used for fitting that can do this, you might be able do a test somewhere as needed?
Sorry to hear what you're going through.
Quoted: 2333 Post(s)
Liked 2,097 Times
Any other ideas?
Any other ideas?
