DIY bike fitting
Technically Canadian
Bikes: Spec. Enduro/Santa Cruz Chameleon/Franken Road Bike w/ Dura-Ace+Ultegra
DIY bike fitting
Is there a site, software, tools that's CHEAP or FREE somewhere online that helps you do basic bike fitting yourself???
I'm just working on saddle height and position and don't have the cash to pay someone to tell me where to run my saddle...
Thanks
Thanks
Cant we all just ride along???
Bike ≠ Car ≠ Ped.
You could get a friend and follow the instructions at Competitive Cyclist, or you could listen to your knees, too.
There are plenty of others.
Bikes: 2006 Cannondale CAAD8
there are to many errors with the measurements to actually be able to use a site. just keep adjusting until it feels good.
Faith-Vigilance-Service
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
CC is a good start for an initial setup.
Everyone is differant though, even if your measurements were to come out the same. As Jynx said, once you have a baseline for your geometry, small adjustments can be made to tweak until you are a perfect feel/fit.
President, OCP
--"Will you have some tea... at the theatre with me?"--
President, OCP
Bikes: 2009 Felt F75, 2007 Trek 7.2FX
If you're just working on saddle height/position, you just need to pick up a few tips to get started.
You can read https://www.peterwhitecycles.com/fitting.htm and have about as much theoretical knowledgeable about 'proper fit' as your LBS does. What you won't have is experience (which, IMHO, is sometimes worth paying for).
Once you get saddle position within a reasonable range of where it 'should' be, you have to adjust based on your preferences, and this just requires more miles (I'm eh.. still in this stage). In other words, don't get your hopes up for an online fit calculator that will be capable of giving you a perfect fit, not even for saddle position.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Do a search within these forums. We've posted enough information over the years to make a decent, if not good, DIY fit system.
Dont you just know when your position is right. I put together a bike at the beginning of the summer. Adjusted the saddle to a height based on my hip bone. Havent touched the saddle height since. A little fore/aft adjustment to get a good knee pedal relationship and that was it. Its a bicycle, not much to adjust.
I don't even know where to start replying to this post......
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Recovering mentalist
Bikes: Too many
Obviously, the OP doesn't see bike fit as the simple matter you do and came asking for advice.
Since the art of bike fitting is such a rudimentary matter to you, why not attempt to impart some of this basic knowledge.
Or are you just wanking for effect?
I'd also be interested to learn about this magic "hip bone" rule.
Quoted: 11 Post(s)
The hipbone rule only works well with beach cruisers.
Fitting shouldn't be so secretive someone cant do it on their own!!! And there has to be basic starting points to go off of!
This article covers the basics.
Hip bone rule. Basic starting point for saddle height. Raise saddle to hip bone height. Its the way I set the height on my bikes. Gets me within a cm of correct height depending on BB height and wheel/tire diameter
