Help me choose a bar tape color.
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
After quite a while I found hoods that fir the Dia Compe Gran Compe brake levers on my 84 Team Fuji. A
member was kind enough to send me a set no charge.So now that I have the hoods I need to put new
bar tape on. I want to try cloth tape and I have 2 rolls of the blue tape pictured which isn't an exact match or would you suggest yellow?
The blue doesn't work for me. Yellow is kind of obvious I guess, but it's sometimes hard to match, and the wrong shade always looks sort of pathetic to my eye. I would probably just go with black to match the saddle. It's a pretty bike, and an argument can be made for letting the frame do the talking.
Likes For due ruote:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 600 Post(s)
Liked 478 Times
This might be the only time I recommend black, but since the saddle and tyres are already black, it could work.
White is my preferred "neutral" option, and it normally goes surprisingly well with yellow. Being a third color in this case, means it will match perfectly (with itself)
Do you like bright, or dark? White or black, there you go.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I'm here for this thread
Quoted: 677 Post(s)
Liked 459 Times
ed over the years
Quoted: 929 Post(s)
Liked 1,289 Times
My Miyata has a similar color scheme and I went with yellow tape. I really like it, especially with the yellow cables, which you also have.
Likes For davester:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
For me, it all goes together: tape, hoods and tire walls. Change one, I might want to change to another.
With an open palette, I would first look at the catalog. It seems, Fuji always made the right choices with respect to these three (or four, because they used different colored/texture saddles as well). Even if you're not a Fuji fan, you gotta admit their catalog pages of their lightweights are pretty sweet.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
White cloth tape becomes brown cloth tape very quickly. I would expect the same to be true of yellow, and to a lesser extent blue. With white tape, it's a good look. It shows the bike has been ridden. With yellow, you're probably going for "pop" and the dirt would take that away in a hurry.
As others have mentioned, "almost matching" colors can look really bad. I think you could probably match that yellow, and I think that would look great, but not with cloth.
My yellow bar tape bike:
The Salsa cork tape cleans up pretty well, but you can see here that it's showing a bit of dirt.
Cloth ends up more like this:
(No, I don't use the drops much, but the camera is hiding some dirt even there.)
My Bikes
My Bikes
Likes For Andy_K:
Novist senior member
You already have the yellow cable housing. The bike has yellow accents. Yellow tape and a yellow seat.
The dropped
Liked 1,014 Times
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 273 Post(s)
Liked 416 Times
pink tape would look nice
that's a lovely bike btw
the headbadge and chrome fork crown are really cool
Quoted: 837 Post(s)
Liked 1,080 Times
Maybe consider looking for a multi colored tape. Like blue with yellow dots or something. They’re out there.
Your frame already has a lot of color. While bar tape ~matching the yellow head tube might look okay, you can't go wrong with black.
I.C.
I.C.
Are you going to shellac the cloth tape? If so, I think you can probably get something that matches the blue of the frame pretty close depending on how many coats you go with. Wrapping bars in bright colors only works if its a bonkers paint job, like a Miami Vice or splatter or something already gaudy on purpose. That Fuji's got a classic, understated look, yellow would be too much. Like putting spinner rims on a old Jag. If not blue, black to match the saddle.
Likes For degan:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
There's your answer ^.
Likes For Phil_gretz:
Quoted: 2323 Post(s)
Liked 4,936 Times
If it helps, here's a few from my Team Fuji.
This is with the stock blue still.
And then with the yellow I finally decided on. I did like the look with the yellow a whole lot more.
Steel is real...and comfy.
Quoted: 3803 Post(s)
Liked 3,324 Times
grey
there is so much colour happening already, more colour is overkill
the grey will look good when new and also as it ages/collects soiling
bright colour on casing and bar wrap can often give the completed machine that dreaded "worked on" look...
grey
Bike looks more purple than blue. Blue tape doesn't look right. Yellow is best, black is second best.
Quoted: 677 Post(s)
Liked 459 Times
Strange. The only yellow on my Team Fuji is on the headset like in the stock photo someone posted
Liked 4,936 Times
Bikes: One beautfiul bianchi (additional information pending)
Agreed. With the purple tint of the bike blue tape would add more colors and could come across cluttered. I'd go for a color match on yellow for an intense complementary color look, or more discreetly with black (or purple if it goes with the frame color).
