Shimano Di2 and Dropper Posts
Hi all,
im looking to see if anyone has had experience using dropper posts with Di2 road levers. My initial thought was:
-GRX left side dropper post lever (ST-RX810)
-paired with an older Ultegra 11speed Di2 rear lever (but finding one that fits the profile of the GRX lecer)
-then replacing the GRX grip/lever itself with an identical Ultegra lever to ensure they match in appearance and fit
so essentially, I’m looking to make sure both levers look and feel the same - while maintaining the functionality of the actual GRX dropper lever.
Welcome all thoughts / suggestions / prior experiences.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I don't understand what you're saying. "paired with an older Utegra lever (...that fits the profile of the GRX lever)? How do you plan on doing that? So you've got a 1x? Why would you even bother putting a GRX lever on "then replacing the GRX lever itself with an identical Ultegra lever..."? Your post makes no sense as written.
-I want to use the GRX dropper post lever, but with a Di2 rear lever
-the Di2 rear lever (ideally) needs to have the same outer shape/grip as the GRX lever
-would (ideally) be looking for a Di2 lever that matches the outer grip, and then just replace/repair the (lever only, not entire mechanism) on the GRX dropper so they both look / are badged identically as Ultegra
I think that ST-RX815-R and ST-RX810-LA is probably the closest match you're going to find. Why do you want to de-badge them and re-badge them as Ultegra? I don't think you'll end up with anything prettier than the way the parts came out of the box.
Bikes: lots
Liked 2,932 Times
-I have a 1x system, with a dropper post
