Spoke nipple pulled through rim
Quoted: 5 Post(s)
I was riding my normal route home from work which entails a slight wooded area, i hit a wooden stump in the ground which caused three spoke nipples to pull through the rim. I got home and took the tyre and tube off and put the nipples back through the rim, they are sitting fine and not falling through the holes. I decided to tighten all the other spokes as they seemed loose and have completely buckled the wheel. Do i need to get a new rim or can the wheel just be trued. Also, i cannot seem to upload any photos.
Quoted: 980 Post(s)
Liked 580 Times
If your spokes pulled through the rim, you will almost certainly need a new rim.
You have to have a certain number (10?) of posts before you are allowed to attach images.
Steve
Steve
Quoted: 5 Post(s)
The spoke nipples are still sitting fine, i am taking it to a bike shop tomorrow but i dont want to be screwed over.
Quoted: 5 Post(s)
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
You will definitely need a new rim.
Calamari Marionette Ph.D
How could they possibly pull through and then fight tightly again? Something is wrong with this story, or the way it's being told.
Likes For SquidPuppet:
Quoted: 5 Post(s)
Quoted: 1815 Post(s)
Liked 1,693 Times
If a spoke nipple actually pulls through the rim, the spoke holes have been enlarged enough that the spokes can never be tightened enough to be under stress ever again. The rim cannot "heal" itself to where it was before. It is toast
Quoted: 980 Post(s)
Liked 580 Times
Steve
EDIT: As others have noted ^^, the rim's holes will have been permanently deformed. Aluminum is not a very elastic metal (and neither is brass, for that matter). For the spoke nipple heads to have passed through the rim, either the rim or the nipples would have had to be seriously distorted. The bike shop will probably tell you you need a new rim... they will not be trying to rip you off.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
You definitely need a new rim. You may actually find that it could be cost effective to replace the entire wheel rather than rebuilding with a new rim on your old hub.
bikeolly, When a nipple is pulled through a rim, one or both mating surfaces will be damaged. My daughter T-Boned something years ago and she too pulled out three (IIRC) nipples. The rim survived with no damage. The brass nipples were too damaged to re-use. I had spare spokes and nipples, luckily.
Brad
Brad
Brad
Brad
I think I'm more inclined to build a new wheel around the SA 3 speed hub, which still works great, and use it on a different bike, and hang the Schwinn in the rafters to collect dust.
Quoted: 1422 Post(s)
Liked 7 Times
What kind of rim?
I would guess holes are slightly oversized or nipples could be slightly undersized or a bit of both.
But, if they pulled through once, they will pull through again and each time a bit more material will be shaved off or compressed making it easier the next time.
Heh, I've got an old Schwinn racer of my father in laws that I fixed up into reasonable riding condition. The dang steel rims are kind of a deal breaker though....rusty enough in a couple spots to make braking even in dry conditions an adventure. I suppose I could replace them with AL rims, but it would sort of ruin the whole vintage aesthetic of the bike, which is the only reason I've hung onto it.
They ride nice for just tootling around. Especially when you delete a few pounds of rotating mass. Polished aluminum rims can go a long way toward maintaining the faux chrome steel vintage look.
Shamelessly posts photo of my '77 Speedster.
Old Schwinns don't deserve to collect dust in the rafters.
I do like this bike, and I do need a project for the winter. You're right though, they DO ride very nicely if you aren't looking to go bombing around at speed. I'd have to strip and repaint this thing for sure, which I'm not totally opposed to doing.
That's a purty bike
Brad
