Bushnell Eccentric and ISIS BB
Old 04-11-22, 06:03 PM
New2Two
Quoted: 12 Post(s)
Liked 4 Times in 2 Posts
Question for those that use the Bushnell Lightweight Eccentric and ISIS bottom bracket, do you experience any binding of the cranks? I just picked up the Bushnell Ecc. and when I tighten the eccentric, the ISIS bottom bracket axle does not spin as freely as when the eccentric is loose. I never had this with the wedge style eccentric. The bottom bracket is the Truvativ GigaPipe with aluminum cups. Would a BB with steel cups, such as the Origin8, prevent the binding?
New2Two is offline
Old 04-12-22, 05:44 AM
IPassGas
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times in 69 Posts
We have a rohloff and thus 2 bushnell eccentrics. We use square taper BB with never a problem, lasts many miles >15,000. Some ISIS BB makes have rather small bearings owing to the larger interface which causes much faster wear which may be your problem. Perhaps Rene Herse ISIS BB fixed that problem.
IPassGas is offline
