A relatively straightforward way to measure fork rake?
Quoted: 7 Post(s)
I am probably very bad with search because I am quite sure this issue has been discussed extensively previously here, but I was wondering if someone can suggest a relatively straightforward way to measure fork rake? Relatively straightforward meaning can be done at home with decent collection of bicycle tools. I have a custom made road fork that I would love to finding the rake on.
Many thanks in advance!
Randomhead
Liked 3,665 Times
put the steerer on a book that lets it lay flat. Measure to the dropouts, average the measurements, subtract the thickness of the book.
Quoted: 4260 Post(s)
Liked 1,458 Times
If it is in a frame you can measure to the center of a chainring bolt, raise the bars and turn the fork backwards and measure again. The difference is twice the rake.
Quoted: 4172 Post(s)
Liked 3,793 Times
And subtract the steerer's radius. Or use a block that lets the fork be measured rake up and rake down and find half the difference.
Not yet mentioned is the axle to crown and the brake hole to crown measurements. Andy
Randomhead
Liked 3,665 Times
or use Kontact's method with the book
How do you measure a/c? I just use my fork fixture. Although the scale is messed up for tapered steerers.
Liked 1,458 Times
One advantage of this method is that you will get very close to the same answer regardless of whether you have the exact rake or not. Even if you get rake wrong by 10mm, it will only change the calculated a/c by 1mm.
This is the reason that measuring to a random point on the bottom of the crank also produces reasonably accurate results for the rake measure - the angles are too shallow to matter that much.
Decrepit Member
Here's how I do it.
Quoted: 7 Post(s)
Thank you for all suggestions, I just tried measuring and I am coming up with 56-57mm rake for a road fork (372 a/c, and it has CX crown). Interesting, it almost looks like it was designed for some kind of rando bike with fat 650B tires... Hmm.
Fat 650B and 700c-35 will be nearly the same.. so a lot of bikes get converted.. 27" wheel , adding longer reach braked..
