Gloves that work on touchscreen - UK?
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 834 Post(s)
Liked 332 Times
You can get a liquid, such as AnyGlove, that gives the touchscreen capability to principally any glove. It works at the so-so level after you cover a sufficiently large area on the glove finger.
Sr Member on Sr bikes
Here’s another idea. Maybe you could modify the glove. Cut finger off an old, unused glove. Cut off the tip of the good glove, and sew the finger from the old glove with just a couple of stitches so that you can easily pull it off to expose your fingertip, and then pull it back over. Something like this…
Link — https://www.shopmoment.com/products/...SABEgKlivD_BwE
Dan
Dan
Quoted: 2475 Post(s)
Liked 722 Times
Siri, send a post to BikeForums Winter Cycling Forum. "Ok, what do you want me to say?" Siri, say that voice controls work much better than destroying perfectly good gloves with scissors ...
Siri…are you sure the OP uses an iPhone?
Dan
Dan
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Use a fingerless glove that converts into a mitten via a mitten-flap. Pull the mitten-flap off just for when you need to use the touchscreen, put it back on when you're done. That's what I use and is the perfect cold-weather layering system for me.
