Noise!!
Old 01-13-08, 04:33 PM
zencadance
Bikes: litespeed, MASTER X LITE, trek
Noise!!
I get a clank noise every time I ride out of saddle and the crank arm comes down from the top?The bottom bracket cheched out ok,pedals are tight and well greased so what gives it drives me crazy.Is it flex?
zencadance is offline
Old 01-13-08, 06:36 PM
drissel
drissel's Avatar
What about crank arms???
drissel is offline
Old 01-13-08, 06:39 PM
turtle77
break-beats
turtle77's Avatar
Yeah, check your chainring bolts. That's a common problem.
turtle77 is offline
Old 01-13-08, 08:06 PM
ultraman6970
HI....
Change the front wheel Skewer. I had the same issue, the noise was there, then not. Sometimes after 10 mins showed up, suddlenly stopped, then shoed up again. I even thought the frame (or the fork) had an internal crack or something.
After retighten BB, Bolts, changed the stem, greasing all posible places where the noise could be generated a friend suggested to change the from quick release... I found a QR that had probably 20 years old, and no more noise EVER!... Put an old steel QR if u have one, I bet the noise will go away. Just in case my frame is carbon. Hope yours is carbon also. THe problem is that carbon is really good sound conductor so sometimes a sound that is generated in the back of the bike for example it will be louder in the BB shell...
Hope this fix your problem
peace!
ultraman6970 is offline
Old 01-13-08, 08:07 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times in 18 Posts
https://www.sheldonbrown.com/creaks.html
operator is offline
