Is There A Reason Why Threaded Freewheels For 120mm Hub Max Out At 34T?
Quoted: 960 Post(s)
Liked 1,626 Times
Jus Thinken...
I have been real happy with my economical Shimano 6 speed 14-34T touring freewheel and; I actually spend more time on my 34T cog than I would like to admit.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
They don't, or didn't. Suntour made a 38 as did Sachs. Of course it was helicomatic but it was still a thread on.
I'm sure there's specific engineering arguments for why they didn't go bigger but the obvious answer was to add smaller chainrings to expand the range of gearing.
edit...on second thought, the Sachs was likely spaced for 126. I've got one and will check.
Quoted: 5888 Post(s)
Liked 3,471 Times
Not much demand and not many RDs that have that sort of capacity. The real problem is that you are talking about huge jumps in your gearing since you can only fit 5 or 6 in 120 OLD. Better to go smaller up front to get the gears you need either with a triple or a "compact" double. That's how I just set up my 70s Motobecane Grand Record, with 50/34 chainrings and a 14-28 freewheel. If I needed better climbing gears, I could have installed smaller chainrings.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
According to Sheldon Brown:
Beyond 6-speeds the axle starts becoming an issue, especially with lower gears or in touring conditions. So you risk the axle snapping.
But if it is 120 OLD you are looking for then check out this 120mm cassette hub by SunXCD (Modern Suntour) and build your own 6/7-speed cassette in 14-36 if you want.
Freewheels screw onto the hub without any tools, then, as you ride the bike, your pedaling effort tightens them down.A freewheel that has been ridden for a long time, especially by a strong rider with low gears, may be quite difficult to remove because the threads are so tight.
Likes For JaccoW:
Phyllo-buster
Liked 2,054 Times
The Sachs SDS-8 was indeed 120 but not a 38 tooth. At least you got 8 cogs...
Likes For clubman:
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
Quoted: 1829 Post(s)
Liked 3,372 Times
With a suitable triple crankset, there's really not a reason to go bigger than 30 or 32T.
Steve in Peoria
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Obviously, cyclists back then were much stronger and tougher than the softies we see today.
Actually, I suspect it is because the >34T sprockets are mainly useful for off-road riding, which didn't become popular until around the same time that freehubs/cassettes also became popular.
Likes For JohnDThompson:
Quoted: 4722 Post(s)
Liked 3,036 Times
Liked 3,036 Times
In the 1960s Chuck Harris offered super wide gearing set-ups in limited quantitites, under his Beech Hill brand. Frank Berto reported that Harris' favourite set-up paired a 13-17-26-34-42T freewheel with 68/44/26T chainrings. In addition to manufacturing the cogs and chainrings, he also manufactured the deralilleurs to handle them.
Quoted: 1140 Post(s)
Liked 1,736 Times
For the Back In The Day part of it, I think it was less an issue of lack of demand and more that triple cranksets with small inner chainrings were a far better/easier solution. For all the reasons called out above.
I think the move to those few 38t freewheels was due to the touring boom and the emergence of the ATB market, where a larger number of buyers found a need for gears lower than 24f/34r. And by then the market was moving to 126mm axle spacing.
For the present day part of it, I think it's a combination of lack of enthusiast demand for 120mm freewheels, and low overall production volume. But I know pretty much nothing about modern worldwide low-end bicycle spec.
And for significantly lower gears on a vintage 120mm-axle rig, either a triple w/tiny granny gear or a double with significantly smaller rings is still the easiest/best route to Low Gear Nirvana. And good luck trying to find a front der that's going to allow a small outer ring on a vintage frame with over-bb cable routing. Even under-bb routing can be tough.
Fuggedaboutit!
Fuggedaboutit!
Liked 3,036 Times
Liked 3,372 Times
that reminds me of a couple of articles in the Rivendell Reader about Mr. Chuck Harris.
I've got the first one scanned from issue #5 (just scanned it today).
There's another one that I have yet to scan, which gives details about one of his bikes and the drivetrain. Amazing stuff!
Steve in Peoria, where the scanner has been getting a heck of a workout lately!
Likes For steelbikeguy:
Quoted: 2333 Post(s)
Liked 2,097 Times
5 speed freewheeled bikes were often setup for half step gearing.
14-17-21-26-32 and say a 45/50 up front. That is what I used. I don't recall anything bigger than 32 and if so, it would mess up the half step pattern.
Quoted: 765 Post(s)
Liked 658 Times
I have a 14-17-21-26-32-38 Suntour Perfect on my Miyata 1000, with a 28-42-46 in front. It's a good half-step setup. I don't use the 28-38 very often, but I find it comforting to have it available.
Suntour Perfects are cheap, plentiful, and easy to customize. The 38 cogs aren't exactly plentiful, but they're not hen's teeth, either.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,194 Times
My "Beast of the East" Suntour ProCompe Ultra spaced 6 speed in my 120mm spaced 1971 Schwinn Paramount P13.
IIRC, 17-20-25-30-34-38 coupled to 50-42-31.
The Suntour 38T will fit on Perfect, ProCompe, Winner, New Winner, and Winner Pro and I believe Alpha bodies. They are not easy to find, but keep checking ebay.
Bob
Bob
Liked 3,372 Times
A mystery for the ages!
... or did the Duopar-ish Mountech handle cogs of that size?....
I'm also trying to figure out why I have this derailleur, but no plans to ever use it.
Steve in Peoria
Liked 3,471 Times
I'm scratching my head trying to figure out why SunTour made a 38T cog when none of their derailleurs (to my knowledge) could handle it.
Steve in Peoria
Steve in Peoria
Liked 3,372 Times
I've been riding my Borthwick for TOMRV lately, configured with one of those fancy modern 8 speed cassettes. I think it is 11-28 right now, and with the 34-50 compact crank, it handles the hills of TOMRV well enough.
I'm pretty sure I used to ride the Borthwick with a 39 x 26 low gear, but that was probably 30 years ago. The hills were smaller then.
Steve in Peoria
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I had to do a double take. I have a coupled bike in British Racing Green.
Liked 3,471 Times
maybe if I was running a 42-52 crankset.
Steve in Peoria
Steve in Peoria
Phyllo-buster
Liked 2,054 Times
Steve in Peoria
Steve in Peoria
Likes For clubman:
Liked 3,471 Times
SunTour AG Tech derailleur (5000)
this has a discussion of the AG rear derailleur and Suntour’s 14-38 5 speed freewheel
Likes For bikemig:
Liked 3,372 Times
