Shimano nexus missing anti rotation washers
Shimano nexus 7 missing anti rotation washers
I have a sunrunner ebike that I recently bought 2nd hand. I loosened the axle nuts to move the wheel back to allow me access to the roller brake grease port then tightened it all back up. When pedaling I felt the hub slip so checked and it had rotated.
The bike doesn't have any anti rotation washers and seems to just rely on the grip of the washer to the frame (axle nuts were incredibly tight before I started work on it). I assumed the drive side had a silver nexus anti rotation washer but it's just some silver flat washer.
Can someone confirm I need a 6L and/or 6R washer?
Dropouts are 10mm wide, axle flats are 8mm, it has what looks like a lock washer with 17mm flats that actually sits inside the dropouts.
Quoted: 6178 Post(s)
Liked 4,795 Times
The people that made your bike should know... I hope.
I'd ask the bike manufacturer if it was intended to have them and they were left off by someone. If they don't respond to your inquiry, then just leave a review for that bike and tell everyone that the manufacturer doesn't answer questions that customers have.
Certainly I'm not saying to leave a flaming review, however this is the sort of information that I look for when I consider user reviews. Flaming reviews get ignored as do overly raving reviews with little detail about why they like the product so well.
Quoted: 980 Post(s)
Liked 580 Times
Nexus hubs *require* anti-rotation washers, as substantial torque is applied to the axle unit even without supplementary electric motor power. I would not ride the bike until you get the right anti-rotation washers installed. Serious harm may happen, or at least you may have your shift cable ripped out as the hub slips.
You can see the different washers HERE. If you position the wheel in the frame so the cassette joint (the thing the shift cable enters at the rear hub) is pointing in the right direction*, you may be able to observe the relationship of the axle flats to the dropouts and deduce which washers to get. You could also take the bike to a shop that services Nexus hubs and let them help you select the right washers.
*Generally, the cassette joint should be oriented so the shift cable points in a generally forward direction, and stays clear of the chain.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Doesn't this model have a brake arm that fastens to the chainstay?
https://si.shimano.com/pdfs/si/SI-75E0E-000-ENG.pdf
https://si.shimano.com/pdfs/ev/EV-FH-IM70-2206B.pdf
The hub is a 7 speed SG-7R46 and the service manual shows the 2 non-turn washers
https://www.avantum.bike/downloads/S...peed%20Hub.pdf
The roller brake arm is attached to the frame.
is 10mm the standard dropout size for the non-turn washers?
Senior member
Quoted: 942 Post(s)
Liked 656 Times
Quoted: 980 Post(s)
Liked 580 Times
FWIW, the clip on the chain's master link is usually recommended to be installed with the closed end in the direction of chain travel. Yours is installed backwards in the second image in Post #1.
Liked 341 Times
My first Scwhinn Typhoon had a similar arrangement. The brake arm handled the torque. The axle nut was just a regular nut, with a washer.
Is there something in these hubs that transmits torque to the axle?
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Thanks, Dan. But I look at this thinking of a "free body diagram". (You may know this approach better than I do, pardon me for explaining). So I look at the axle. It's separated from the hub's torque by bearings. The hub has on one side the freewheel and sprocket(s) and is separated from the axle, with little torque transmitted, by the same bearings. The roller brake assembly has its inner part fastened to the hub on the ND side, and this part rotates (normally with no torque tranmitted to the outer part of the brake because of a bearing. The outer brakepart is attched to the inner part by a bearing, and to the frame by the brake arm and clip. No braking? No torque on the outer brake part. Braking? The inner and outer brake parts transmit torque to each other, and the inner part transmits torque to the hub, but I can't see where torque gets transmitted to the axle.
Your Schwinn Typhoon probably had a coaster-brake or perhaps a Bendix two-speed kickback hub. I believe the torque arm did double duty on the kick-back hub because the sun gear/adjusting cone was locked to the axle.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 980 Post(s)
Liked 580 Times
Senior member
Quoted: 942 Post(s)
Liked 656 Times
There sure is. The sun gears are reactionary gears affixed to the axle. In underdrive gears, the torque will act on the axle in a rearward direction. In overdrive gears, the force is in a forward direction. The axle must be braced against this rotation force.
Likes For Dan Burkhart:
Liked 341 Times
Thanks, Dan, Jeff and Rich110 for the info. I'd seen the Nexave label and assumed that the hub was a Nexave and not a Nexus. Clearly the pictures show that it is an IGH and not a freehub! Thanks for the education, guys.
So the OP needs a 5, 6, or 7 L and R anti rotation washer set. These vary according to dropout angle. See page 20 of this document. 5 size washers for angles of 20° or less, 7 size washers for 20-38°, and 6 size washers for 0°.
thanks for the help guys.
If I put a NTW washer on first, the chain tensioner adjusters won't work/fit because they will be too far out. They only work if they are placed on the axle first.
The NTW are 6mm wide. I placed the 3mm washer on the inside in this pic to demonstrate. Can i just remove the chain adjusters completely?
6R 6L is what I will try and get
Senior member
Quoted: 942 Post(s)
Liked 656 Times
Quoted: 980 Post(s)
Liked 580 Times
The roller brake assembly has its inner part fastened to the hub on the ND side, and this part rotates (normally with no torque transmitted to the outer part of the brake because of a bearing. The outer brakepart is attached to the inner part by a bearing, and to the frame by the brake arm and clip.
Likes For sweeks:
Does it matter which way the washers face?
Even if I lengthen or replace the chain, the brake arm that attaches to the frame is already as far back as it will go! There is no way I can place the washers facing the inside of the dropouts without extending the brake arm somehow.
Are they OK facing backwards?
In the workshop manual for the newer roller brakes (p12) it shows the NTW facing the open end of the slot. for a horizontal dropout it shows it facing the inner part of the slot. I assume that is because of the chain adjusters?
edit: nm found it
edit: nm found it
Likes For rich110:
