A tall Calzone at the LBS
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,393 Times
Sorry, not a food thread
Found this at the LBS with a painfully stuck Nuovo Record seatpost in it. Thought it was an interesting bit of framebuilding worthy of a few pictures - plus the "C" lettering might help for future identification threads.
Couldn't find much other than this reference on the Italian Cycling Journal blog: ITALIAN CYCLING JOURNAL: The "Bike Guide"
CALZONE: Italy. Domenico Calzone. Trained by Giuseppe Pela and Armando Zago. Via Villa Giusti 6, Torino Italy. Imported by Frank Israils, Ft Lauderdale FL. Information, Dade Cycles, 305-***-****. Most were green with yellow & gold.
The through-the-BB front derailer cable is a nice touch. No sealed BB's for this one - there's a guide tube running through the BB shell.
Something chewed into the dropout. Don't know how on earth this could have happened, though this is not the bike's original wheelset, so...who knows?
-Kurt
Likes For cudak888:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Interesting frame, for sure. That's the first "through" the BB shell cable routing I recall seeing. 🤔
Quoted: 3811 Post(s)
Liked 3,336 Times
Me too!
usually order ricotta and spinich
mangled dropout -
its a longshot but one possibility might be that an assembler discovered frame constructed with the left seat stay made longer than the right...
Liked 4,393 Times
I saved a picture for when that comment came up. Headtube is steeper than the seattube on this as built. No wrinkles to suggest any front-ender.
Now that everyone shoots with cell phones, everything is cropped off a distorted wide-angle sensor. Note that while the fork looks fine now, the top tube appears bowed. I can tell you for sure that it isn't.
-Kurt
-Kurt
Likes For cudak888:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
-Kurt
-Kurt
Likes For USAZorro:
Quoted: 4233 Post(s)
Liked 2,948 Times
What happened to the dropout?
Quoted: 18373 Post(s)
Liked 4,508 Times
https://www.bikeforums.net/bicycle-m...-accident.html
In this case, the wheel was apparently improperly dished, so the rim was closer to the NDS than the DS. So to correct the dishing problem67k, someone filed the DS dropout down and back, and the NDS dropout up.
If the OP's Calzone frame is in alignment, then you might be able to carefully weld in filler into that cutout, and file flat. Or, simply push the dropout adjustment screws as far forward as possible and mount the wheel in the front section of the dropouts.
Quoted: 586 Post(s)
Liked 612 Times
Why am I suddenly hungry? That is a really nice bike for a taller rider. With some prep and touch-up, it would make a nice rider. Most of the paint seems to be OK. The overall workmanship appears very good. A little touch-up, some protective wax and it will be just fine.
Not at all familiar with that brand. Does anyone here have one in their stable they want to show? I guess I could do a search in the forum too.
Liked 4,393 Times
Here is an earlier thread with similar "Damage" to the DS dropout.
Whatever the case, there's a Hobart 140 at the shop (though not with Argon/CO2), so they should be able to fill that up and file it out without having to burn off paint.
Figured it wouldn't be a bad idea to get this (apparently textbook) example documented.
-Kurt
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
I think you've got me on an Italian food binge, lol. I found some really good but cold lasagne last night, at a deli. 😍😁
Hey, I'm in Vacaville now, where they kept Charles Manson locked up for awhile. 😲 I'm not really stuck on that mess, just remember reading about it before. 😎
I might be more interested in Grizzly Island, but not sure about riding through on a bicycle. 🙄😉
Liked 4,393 Times
