Alex Singer Information?
Bikes: Many!
Quoted: 186 Post(s)
Liked 206 Times
Hello list friends,
I was fortunate enough to happen upon this Alex Singer. Beneath piles of children's bicycles and rust buckets caught my eye this very special offering... a potential Alex Singer. Of course, the bicycle followed me, and now my curiosity regarding its legitimacy/history has peaked. Below are a few photographs of the bike in all of its mistreated glory. Please, feel free to share any thoughts as I am looking for information on the bike (besides the little that I might already know). Excuse the condition of the bike, its positioning, and the quite bad photos.
There is a four digit serial number printed on the non-drive side rear dropout.
Likes For SoccerBallXan:
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
That could be a lovely build. Next time I am at the shop I can find out the name of the original order, the paper invoices are all in huge binders back to the 50s. I don't see a serial # on the dropout, just the "brev. campagnolo". If you can read a number post it. Shame about the cracked seat lug, that likely makes it non-rideable unless fixed. If you were willing Olivier would probably repair for you but it wouldn't be cheap or fast. I could show him this thread and ask what he thinks. PM me if you want to proceed that direction.
Likes For poprad:
Quoted: 4510 Post(s)
Liked 6,377 Times
Quoted: 87 Post(s)
Liked 923 Times
That's great info...I'd wondered about those Campy dropouts. They do look odd on a Singer.
Quoted: 87 Post(s)
Liked 923 Times
Right you are Bob, and props from the Man himself:
Likes For poprad:
For comparison here is my Singer 1975 Alex Singer (fattiretrading.com)
Likes For Fat Tire Trader:
Quoted: 3807 Post(s)
Liked 3,331 Times
1978 would make it during the relatively brief period where Spence had the shop in Pacific Grove, California
visited both the original Randy Lane and Pacific Grove locations
always a treat!
absolutely wonderful courtesy, knowledge, graciousness & generosity of spirit
still have in me spares drawers some treasures purchased during the big moving/inventory reduction sale as they were preparing to relocate from Randy Lane to P.G.
have wonderful fun with this outstanding find
always a treat!
Likes For juvela:
Liked 45 Times
For the seatlug, I'd do the most minimal repair possible - a builder should fabricate a splice to complete the ear. If fitted carefully, it could be silver brazed perhaps. That would minimize disturbing the rest of the joint and minimize any possible distortion. But a good builder could do it in brass as well. I've seen Mark Nobilette do splices that were significantly more complicated.
Interestingly, some of Singers that came into the US were actually designed for 27" wheels. There were a couple of frames that came in around the time of this one that went to the Boulder Spoke Bicycle Shop as "spec" frames and at least one was 27".
The Singer frames of this period tend to ride very well. It's very much worth restoring to it's former glory!
Likes For mikekone:
Quoted: 964 Post(s)
Liked 1,451 Times
Where's this crack y'all are seeing?
Liked 6,377 Times
Quoted: 964 Post(s)
Liked 1,451 Times
Still not seeing a crack, only paint chipping, but maybe I am just thick. Looks rideable from here!
Liked 6,377 Times
And I think you're probably right, it could be ridden with a good bolt/washer setup, but given it is what it is, it should be properly fixed first.
Quoted: 192 Post(s)
Liked 566 Times
The transport would add to the cost, but it would be great if this bike could go back to Alex Singer for the repairs and refinishing. It’s beautifully built and quite worth the investment….
Quoted: 964 Post(s)
Liked 1,451 Times
I think that's just the keyway for the seat binder bolt key, (you know, the notch to stop the left side of the binder bolt from moving when you are tightening the right side). I don't think that goes all the way through, and I don't think it's damaged much at all.
Quoted: 87 Post(s)
Liked 923 Times
I'm pretty sure this isn't a crack but an entire missing piece, this should be a continuous metal surround of the binder bolt nut:
For reference a brand new one
Likes For poprad:
Quoted: 964 Post(s)
Liked 1,451 Times
I'm pretty sure it's just a seat binder bolt keyway. To take a seat binder bolt with a key that stops the left side from turning. Like this one. I do not think it was originally hex shaped.
See similar on my René Herse.
From that angle, I can see how it might appear to be a ripped-out section. But, 1) I cannot imagine quite how that might happen, and 2) I can see the bottom of the keyway, dimly, in that photo. Yes, it's cut quite deep, much deeper than my René Herse, but I'm 85% sure that's what's going on here. Admittedly a cruder design than your beautiful new Singer, and it relies on those silly Campy binder bolts with their added weight and infamous stress-risers. But, no brazing needed!
Edit: here are two zoomed-in images. In the first, I outline the edges of the keyway. In the second, it's just zoomed-in. Do you see it?
Likes For scarlson:
Quoted: 87 Post(s)
Liked 923 Times
Huh. Well now I have no idea until OP posts a better-lit photo..
Likes For poprad:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Likes For The Golden Boy:
Quoted: 566 Post(s)
Liked 1,047 Times
I’m dumber than a sack of hammers but is it normal for the binder hole to be squared off on the inside? It looks like a carriage bolt goes in there.
Quoted: 964 Post(s)
Liked 1,451 Times
I think it started out round but someone gouged it a bit on that corner-y looking region in front near the tube, by putting the key on the wrong side and started to tighten it before realizing something was wrong. This sorta makes sense, as many lugs will have the keyway facing forward. Some fool, probably reassembling a new seat binder in there after the original one broke (thanks Campy!), started it out wrong with the key facing forward thinking it was just like any other bike. It made a little gouge which approximates a straight line, giving the illusion of a squared off hole. I've seen worse. My Trek was way worse! My friend saw a bike shop goon do it to his Nishiki when his binder bolt broke on a ride!
Likes For RustyJames:
Liked 6,377 Times
From where I'm sitting, 1000+ mi. away, respectfully disagree, but agree it was a keyway that is now a void, split open by a hamfist and a short attention span. The other side looks to be doing the same but still intact for now. At any rate, and I hate to say it but imho those ears were not robust enough to begin with, all hamfists considered.
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
A mandrel should be placed in the seatpost hole to allow the upper point to be straightened by hammering. Because this is a special bike, this hammering should only be done by someone very good. That probably means a framebuilder, not an LBS mechanic, though there are probably a few mechanics I'd trust with that. Actually none come to mind though. The metal is very malleable and it will bend back without cracking, but let's avoid doing more damage.
I wouldn't even repaint it, if it were mine, though of course the new owner should do as he pleases.
Enjoy!
Mark B
Likes For bulgie:
Liked 6,377 Times
Bikes: Many!
Quoted: 186 Post(s)
Liked 206 Times
Cycling friends,
Thank you for taking the time to analyze the bike and respond with your expertise. A special thanks to poprad who was able to contact Olivier Csuka through email and retrieve more information directly from the source. bbbob thank you as well for sharing your knowledge on Singers; it's exciting to see the small details that point back to Roland and Spence.
The bicycle has surly changed hands many times since its arrival in Pacific Grove. The seller was one of many bike butchers in the city, he only cared for the few parts that read Campagnolo. I will be rebuilding the Singer back to its former glory and will attempt to keep any patina the bike's acquired over the years.
Regarding the seat lug, below are a few more photographs. Upon further inspection, I believe scarlson and bulgie are correct and the "chip" is a notch for a seat binder key.
