Peeling 600 headset decal
The decal sticker that wraps around the Shimano 600 headset on my Miyata is peeling off, slowly getting worse. I'd like to stick it back on, and not have it hanging off or peel off entirely. Has anyone had any luck with any particular adhesive to get it to stick again?
Dab of superglue worked on mine.
Semper fi
Semper fi
Likes For sloar:
Quoted: 2300 Post(s)
Liked 4,764 Times
aka: Dr. Cannondale
Quoted: 2151 Post(s)
Liked 3,380 Times
Carefully applied thin coat of rubber cement works too.
Likes For rccardr:
Quoted: 887 Post(s)
Liked 335 Times
I understand, but you must realize that this is a first world problem. I am going through it now with disintegrating Reynolds tubing decals. Take a deep breath.
Likes For dweenk:
Quoted: 1924 Post(s)
Liked 1,954 Times
Do those 600 stickers do that every time? I think each of mine did that and it bugs.
Sounds like superglue might do the trick. Thanks for the replies.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
FWIW, early production 600 headsets didn't have a decal. Maybe it would look fine without?
Disraeli Gears
Even though I'm very careful, I always find that superglue (cyanoacrylate) creates an uncontrollable mess; less so with the thicker varieties, but I would try rubber cement first, used like contact cement: coat both contact surfaces thinly, let dry for a few minutes, then press together. You could tape the end of the piece to help hold it, but the rubber cement will (and needs to) off-gas for awhile to create the final bond. The nice part about using rubber cement is that you can rub off any excess when it's fully cured, and have no mess at all. Also, it's removable (with Bestine = heptane) and renewable if it comes to that.
