Hello from Florida
Hello from Florida
I am just starting to ride more. Someone gave me a Sigma Sport BC 1600 wired computer. I have measured the tire on the floor converted it by 25.4 also found site that gave the tire size but the 1600 still not not record the correct distance, off by a little less then a quarter of a mile within the 1 mile I rode. Any ideas are welcome.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Welcome to Bike Forums. We have moved your thread from our Introductions forum to our Electronics forum.
Quoted: 3459 Post(s)
Liked 1,465 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
3.14 *(BSD + (2 * tire width) ) works surprisingly well.
Though I do a rollout for at least two revolutions of the wheel and divide by the number of revolutions. Everything converted to millimeters.
You can put a spot of ink or paint on your tire tread and look for the marks if you don't care about the surface you are marking up. Ensuring your tire is inflated to your riding pressure and you on the bike might make it even more accurate.
You can be off by a little more than 1.6 inches (42 mm) and still be 2% margin of error if this is a 700C tire.
Liked 1,465 Times
My 37mm wide tire that is 700c would be very close to yours, I use 2204mm in my bike computer for that tire. That is very close to the 2197mm that your tire would be.
If your distance that was measured was much shorter than the distance traveled, could be weak battery or could be the magnet was not close enough to the wheel sensor.
If the battery is new and the sensor is quite close to the wheel magnet, maybe it would be best to take the battery out of the computer and let i sit a few minutes so that the computer forgets everything. Then put it back and and start all over including entering your wheel data and trying one more time.
If it is a wired computer, sometimes a wire that is broken could provide sporadic readings.
I am assuming you have a computer that can provide both mile and km readings, make sure you set it for what you want. When I go to a foreign country, I change my setting to km so that my distance matches the maps and road signs. Once when I came home I forgot to change back to miles, took me a couple days to figure out why my readings were so screwy.
Liked 4,808 Times
There is always the question of how do you know the distance you compared it to is correct.
Likes For Iride01:
Quoted: 523 Post(s)
Liked 229 Times
This is the first bike computer I came across that doesn't have a setting for mph vs kph but requires you to put a different setting in for the wheel circumference. There is a wheel size table in the manual listing 700C X 35 and 700C X 40 but no entry for 38. The mph setting for 700C X 35 is 1370 and for 700C X 40 is 1381. The closest estimation for your tire would be 1376. If the number you calculate using a runout is much different from this value, that is your problem with accuracy. See page 14 https://www.manualpdf.us/sigma/bc-1600/manual?p=6
Liked 1,465 Times
Based on Vegas Triker info, I obviously gave you incorrect advice. I appologize. Every computer I have used required the circumference to be entered and has a choice for mph or km/hr. I am guessing that your distance traveled that you assumed was incorrect when you irst tried it was the km that you traveled, not miles.
I checked the distance with my vehicle. I would not think I would be 1/4 of a mile off in 1 mile. I will leave the battery out for a longer time and put the readings mentioned above tomorrow. The magnet connections look very close maybe a 1/16" or so gap.
Liked 4,808 Times
You've never stated exactly what calibration number you put in. Was it the 86.5" converted to millimeters which is 2197?
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
The bike computer sensor reacts to the magnet passing by. The computer counts how many times the magnet passed and scales it with the entered circumference. Any wrong result must come from an incorrect circumference or incorrect counting. A 25% error should be easy to track. The incorrect counting would be due to a weak or incorrectly mounted magnet, but could be also to some poor connection between the sensor and the computer or malfunction of the sensor. Using an easy scaling factor on the computer, such as 2000, and passing magnet by hand by the sensor fast enough could help. Cleaning the contacts to the computer is an obvious action to take as it is cheap.
Liked 4,808 Times
Have you done any more rides since this one? With any trouble shooting, it helps to have some repeatable instances of the issue. If it's an outlier of many rides, the why are we even bothering?
Liked 1,465 Times
1370 / 2197 = 0.6236
1 km = 0.6214 miles.
I think you fooled a computer that was designed to read out in km and km/hr to read out in miles traveled and mph instead. Interesting.
I have the option to select km or miles. I selected miles. If I fooled the computer, I did not know it. But all is good.
