how do i remove a head badge w/ rivets?
Novice Bike Builder
Bikes: Fixed Gear Bicycle w/ an unknown frame, 12-Speed KHS GranSport
im trying to remove an aluminum head badge with rivets attaching it to the bike without damaging the head badge. any input on how i should go about this?
Bikes: NOYB
Center punch the rivets and drill into them with a small (~1/16") sharp bit. This will remove the rivet heads and allow the headbadge to be removed.
You'll need to buy new rivets (or very small metal screws) to re-install it.
I've been able to push the rivets out a bit from the inside of the headtube before, then use diagonal pliers on the outside to pull them out the rest of the way. The rivets can be reused if this method is successful.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
This is my technique, as well. Be very careful and steady with the drill. A shop stand for the bike really helps.
Novice Bike Builder
i remember one of the frames i had were actually screws but looked like a tack so used a di grinder and saw it flush with the frame. i didnt want the head badge but i really want to keep this head badge. im also trying to figure out what kind of centurion bike this is. if you know id like to know. the rivets look like this.. thats the actual bike. where would i be able to get rivets that look like that and would fit correctly? any stores i might be familiar with?
Quoted: 3809 Post(s)
Liked 6,684 Times
Another possibility: Instead of replacing the rivets, you can glue the headbadge back on and use cut off spoke ends in the rivet holes.
Neal
Neal
Bikes: Fuji Monterey, Schwinn Traveler, Fuji Special Road Racer, Gitane Interclub, Sun EZ-1, Schwinn Frontier, Puch Cavalier, Vista Cavalier, Armstrong, Raleigh Sports, Schwinn Stingray
I don't know if you're just collecting the badge and tossing the bike, but if you're going to be painting the bike, you can just mask it off with masking tape. Cut paper in the shape of the badge, then slowly, carefully tape the masking tape to the edges of the badge and fold it down onto the paper so the sticky part of the tape doesn't pull the paint off the badge when you remove it. This is easier if you use many smaller bits of masking tape, you'll go crazy trying to do it with one piece. You can use a dremel tool to remove the bits of rust or flaky old paint in the seams near the badge.
Disraeli Gears
I would try to mash the top of each rivet dome slightly with a large, square-ended punch, and then use a sharp awl to make a little starter divot in the center. Then start with a very small drill, 1.5 mm or less, and work your way up until the rivet gives up the ghost.
Viscount
Bikes: Mercian, Viscount x2, Holdworth La Quelda, Gundle Trade Bike, Williams/Mercian Tourer, Itera,
https://64.233.183.104/search?q=cache...lnk&cd=1&gl=uk
I deliberately didn't link you to the actual rivets, 'cos if you check the site thoroughly you will find all sorts of useful obscure bicycle stuff.
Check it, it is a vital resource IMHO.
Not just decals.
I'm not connected in any way with Lloyds, I just think they provide a great service for the likes of CV fans, and me!
