Problem with Giordana Shorts?
Old 10-20-09, 04:39 PM
Caad 8
Cat-5-O-Meter: Training
Caad 8's Avatar
Bikes: Cannondale Caad 8
Ive seen a couple reviews that say there's a big problem with Giordana bibs and shorts. They say that less than a month after buying them, the chamois detaches away from the shorts! Has anyone had this problem? I was going to buy a pair.
I finally found these in my lbs, which I liked.
Caad 8 is offline
Old 10-20-09, 04:46 PM
DataJunkie
Liked 3 Times in 3 Posts
I have a pair of silverlines that have been going strong for a year and a half.
DataJunkie is offline
Old 10-20-09, 04:47 PM
Dick Rhee
Shoebomber
Dick Rhee's Avatar
Bikes: 2008 Canyon CF Pro w/ Chorus, 2005 Moots Vamoots w/ Ultegra, 1988 Cannondale commuter
I haven't had yet that happen to my Giordana Forma Reds but my Castelli bibs and its chamois did separate pretty quickly. Do you have a link to the reviews?
Dick Rhee is offline
Old 10-20-09, 04:50 PM
Caad 8
Caad 8's Avatar
https://www.mtbr.com/cat/mtb-apparel-...07_145crx.aspx
Specifically its the second, third and fifth one down. But theres a few more here and there.
Of course then there's a lot of glowing reviews too....
Caad 8 is offline
Old 10-20-09, 05:12 PM
rail157
dropped
With the exception of the first two, all of the reviews at that link are over five years old. The second review gives no indication as to mileage, and most of his complaints are because Giordana wouldn't replace stock a year in.
The first one is just weird.
I've had really good luck with my FormaRed pair, no noticeable wear so far. I've only got a couple thousand miles on them, though.
rail157 is offline
Old 10-20-09, 05:42 PM
iab
iab's Avatar
Quoted: 3009 Post(s)
Liked 3,773 Times in 1,405 Posts
I have one pair of Silverlines 3 years old. They are fine. As are 2 more pairs that are 1 year old.
iab is offline
Old 10-20-09, 08:16 PM
fatdad
fatdad's Avatar
Bikes: Jamis Quest Elite - 2014
I have a couple pair of the Laser bibs from Giordana. After two seasons, they look virtually new despite crashing this summer. I wish my skin looked as good as the bibs did after sliding on the asphalt.
fatdad is offline
Old 10-20-09, 08:35 PM
Eclectus
Eclectus's Avatar
Bikes: Cervelo RS, Specialized Stumpy, Schwinn 974
Check to see if pad is glued vs. sewn. If glued, either do not put in the dryer, or keep the temp on "delcate/ fine". For everything, hang-drying is recommended, but glue and heat are most incompatible, since the glue is a hot liquid when applied.
Eclectus is offline
ILUVUK
en fuego
ILUVUK's Avatar
Bikes: Trek Madone 3.1
I also have a pair of Silverlines that are 3 years old. I'm roughly estimating that I have 4,000 miles on them (I rotate). There has been no chamois separation.
ILUVUK is offline
Old 10-20-09, 08:37 PM
Flatballer
No matches
Flatballer's Avatar
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times in 250 Posts
Never heard this. I've got two pairs of Giordana (dunno the model, they're a team kit) bibs that have about 1500 miles each, and they're just fine.
Flatballer is offline
Old 10-21-09, 03:51 PM
javery
I have the Silverlines, and they are fine. I also have some Performance Ultra shorts, and they are of higher quality. The material is nicer, they don't sag in the rear the way the Silverlines do. The cut is also better on the Ultra's. Longer legs and a bit higher on the waist. But Silverlines have a cooler logo...
javery is offline
Old 10-21-09, 04:17 PM
bravo106
molasses in winter slow
bravo106's Avatar
Bikes: '06 Serotta Nove, '04 Mondonico Futura Leggero, '08 Haro Mary SS
I've owned a pair of their Forma bibs for > 2 years and lower-end team kit bibs even longer than that, and have had no problems with chamois delamination. The Formas survived a downhill crash last year with no sign of damage, either. (unfortunately, the same couldn't be said for my hip, elbow, shoulder, and helmet)
I'm wondering if the people who have had problems are using a fabric softener in the rinse cycle &/or putting them in the dryer. I use plain detergent, no softener, no dryer.
bravo106 is offline
Old 10-21-09, 04:29 PM
Enthalpic
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times in 102 Posts
My team bibs have held up pretty well. A couple pairs had their chamois come loose when they were ~2 years old. One pair I tossed, the other I took to a tailor and had it sewn back in for $6.
Enthalpic is offline
Old 10-22-09, 04:29 AM
scirocco
Have three pairs of Giordana Tenaxes, no problems with the chamois, but the fabric is pretty thin and gets stretched out of shape easily.
scirocco is offline
Old 10-22-09, 07:04 AM
Orbital57
Bikes: Condor Italia + Marin Muirwoods (which got me back into riding)
3 pairs of Giordana Lazers with 10k + miles between them and no problems so far. My club also uses Giordana for club kit and I haven't heard any complaints so far (unlike the Sportful kit we had in 2008).
Orbital57 is offline
Old 10-22-09, 01:27 PM
Caad 8
Caad 8's Avatar
Thanks, Im gonna go out and grab em now!
Caad 8 is offline
Old 10-22-09, 06:37 PM
Electric_Elvis
I had a pair of the silverline roubaix's and the chamois seperated at the seem. It happened at about the 8 or 9 month mark, I sent them back to giordana with the receipt and they replaced them with a new pair!
Electric_Elvis is offline
Old 10-22-09, 08:32 PM
hainy
I have 4 pair of the laser bib shorts that I rotate and after 2 years of heavy use still look brand new. I won't use any other shorts
hainy is offline
Old 10-23-09, 07:54 AM
80vette
Gear Head
80vette's Avatar
Bikes: 07' Colnago CLX, 04' Allez,03' KHS, 79' super leTour304
I wear giordana laser shorts exclusively. Never any problems.
My 1st two pair are over 4 years old now. They have gotten a little baggie .. just not as tight, form fitting as they used to be. No chamois seperation. They have been machine washed (gentle) and dried (no heat) in excess of 250 times now and no issues.
80vette is offline
