Centurion Serial Number Database
#2376
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,379 Times
Looks like you have a 1978 in Pearlized Coffee. Photo courtesy of Vintage-Centurion.com https://vintage-centurion.com/literat...on_Catalog.pdf
Twin
Bikes: Centurion Super Lemans
Liked 20 Times
Thank for adding the pictures, and for the brochure.
I put new tires and brake blocks on....it all works very well now.
#2378
Hi everybody. And T-Mar.
I have recently built up a Frankenstein from a frame I purchased as a forkless re-painted structure. There was no knowledge of the brand nor the model.
The bike has a serial number on the headtube above the downtube lug. The serial number is WAKB043503, there could be some misreading, but rather in the end part of the number.
As I have understood from the conversation above and elsewhere it is a Centurion imported to Denmark by Age Kroll. The number, however, is not entirely consistent with the Danish VIN structure. Which has left me pondering.
The frame has been light blue originally. It has brake cable braze-ons, but no downtube shifter brazed-on posts. So somewhere 1981-84?
It has 26.2 or 26.4mm seat tube - 26.2 seems to have a bit of play but fixes fine. The size is 60cm C-T.
I have called it LeMans, but I have yet to see a frame with similar seat-stay upper ends, so not really sure.
If. If someone could provide a better educated guess, I would be grateful.
As a newbie I can not share images. Somewhy. But with some patience one can repair - https colon slash slash drive google com/drive/folders/109xEhaNEXywiNaUmELmlEJG8j5WQjUXg?usp=sharing
Thank You
Thank You
#2379
Quoted: 1924 Post(s)
Liked 1,954 Times
1985 red Ironman. 6207 components with a Tange BB, Technomic stem 42mm B115 bars. 60cm center to top edge of seat lug and 57cm TT CTC.
N4P0265
N4P0265
#2380
Bikes: Bicycles? Yup.
Quoted: 464 Post(s)
Liked 1,452 Times
Centurion Prestige
63 cm frame and fork plus Shimano 600 headset
1989?
sn 89B2317
Money shot. The other side had significant surface rust.
1989?
sn 89B2317
Likes For BTinNYC:
#2382
Bikes: 1984 Schwinn Sierra, 1984 Centurion Elite RS, 1989 Ironman Master
1984 Elite RS (silver)
N4A5075
1987 Ironman Expert (MV)
N7G8041
1989 Ironman Master (red)
N9D5048
N4A5075
N7G8041
N9D5048
#2383
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
Currently cleaning up & getting ready to rebuild this 1981 Centurion Pro Tour. SN M1F15682
I believe this means the bike was built in 1981 for a 1981 sale--the 1982 sale models had all switched to cantilever brakes, no? It seems like the Centurion Pro Tours existed as 3 groupings: the 1976/1977 grouping with partial chrome fork & stays, the 1978-1981 grouping with the full chrome under paint & pin-striping, and the 1982-1984 grouping with cantilevers and 'Pro Tour 15' decals.
#2385
Biker
Like the above bike, my recent purchase appears to be in the mid evolution of the Centurion ProTour SN M8B01504, oddly it also has stamped on the bottom bracket in larger font size 072558 of unknown significance. Mine is the pearlized silver, with barcon shifters, triple crank (Sugino AT 46, 36, 26 which may not be stock). It too has the pin striping, and all chrome tubing. I will start another thread to detail the bike as found, but suffice it to say it has the "fat" C head badge, and chrome lugs to set it correctly in the 79 range even tho the sn suggests a 1978 build. It was at the evolutionary transition. and has been further upgraded by previous owners.
Centurion Pro Tour 1978/79
The chrome lugs are beautiful.
but why were the seat cluster lugs partially painted?
I have a 7 speed freewheel on Campy record hub so 126 spacing and a Suntour xcsport 7000 DR
I'm wondering whether the Sugino AT with low gearing 46, 36, 26 was OEM or a mod?
#2386
I have a Centurion Super Le Mans. Bought in 75 or 76. Serial N5270. Have not found anything yet that pinpoints the year based on that serial.
#2387
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
I just found this Elite 12 at an estate sale. I'm pretty sure the brakes, levers, pedals, and maybe the seatpost are the only original components. Even the seat binder bolt has been replaced with Italian (Miche). Pretty sure this is an '83 because that was the only year for these. N3M6094
Likes For JacobLee:
#2388
Bikes: 1984 Miyata 710 resto-modded to 1x11 townie, 1987 Bianchi Brava resto-modded to 1x11 fitness/events
Quoted: 15 Post(s)
Liked 48 Times
F3105450
The thread seems to have stagnated, or perhaps its purpose has been served. Anyway, picked up this frame on eBay.
Obviously an 89 LeMans. Frame seems to be in great shape although the paint is iffy and there are few rust spots to be fixed. One of the mysterious F3 Taiwan frames.
It’s going to be a “neighborhood” bike for my wife. She wanted something upright and “simple”, so I’m thinking about a 1x7 with mostly parts bin components.
The wheels shown are some pretty new no-name freewheel clinchers I had from a previous build that should work fine. I found a 7-speed 12-32T freewheel and a Shimano 1055 crankset with just a 42T inner ring (not a Biopace) should give a pretty good range of gear ratios. Some Shimano 1050 calipers look like they’ll fit.
#2389
My 89 IM Master non-lugged frame - serial number 89D2966. Gotta be close to one of the last IMs made.
#2390
Re Member
Bikes: little red tricycle
Greetings!
I just acquired an old Centurion LeMans, S/N F9059903
Can anyone tell me the date of this bike?
The colors are primarily white, with some purple on the fork and front/back of frame.
At the back of the top tube it reads "Avenir Equipped".
Thank you.
Thank you.
#2391
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 235 Post(s)
Liked 178 Times
yes, members were all Centurioned out during Covid.
I would suggest that the serial number is F8105450. The "3" is a poorly struck "8". The frame was manufactured in year 8 and month 10, October 1988.
#2392
Quoted: 15 Post(s)
Liked 48 Times
Well, maybe. Hard to prove. It seemed very clear and distinct “3” to me.
#2393
Quoted: 1590 Post(s)
Liked 2,492 Times
Likes For curbtender:
#2394
Quoted: 235 Post(s)
Liked 178 Times
When dating the frame using the serial number it is another matter. The serial number is for a frame made by Fairly Bike of Taiwan. There are many examples of serial numbers from Fairly manufactured frames. It is generally observed that the date of manufacture is encoded in the serial number, as is true for many of the Taiwan bicycle manufacturers in the 1980s.
For Fairly serial numbers the first digit is for the year of frame manufacture.
The striking of the serial number characters into the frame is not always clean and precise. Then the frame is painted. Because of this serial number characters are not always clearly definable at first glance.
Likes For Hummer:
#2395
Quoted: 235 Post(s)
Liked 178 Times
The serial number is for Fairly Bike of Taiwan. The first digit is for the year and the next two digits are for the month of frame manufacture.
Year "9", month "05" is May 1989.
Likes For Hummer:
#2396
Volunteer wrench
Bikes: 1971 Schwinn Suburan, 1971 Peugoet UO8, 1984 Nishiki Cresta, 1984 Nishiki Olympic, 1987 Schwinn Super Sport, 1996 Waterford 1250, 2018 Cannondale Synaspe Carbon
Quoted: 19 Post(s)
Liked 33 Times
I have a Centurion Lemans with a Made in France label. It's equipped with Weinman 620 brakes, Simplex front and rear derailleurs, Simplex shifters. I have not found markings on the wheel hubs nor have I located a serial number. I assume it is an early '70s model but I can't anything about them being built in France. Here's the photos
#2397
Biker
Frenchified Centurion
I'm no expert but it looks like you have an unknown bike with old centurion decals. Love those lugs.
Likes For Peruano:
#2398
Liked 2,492 Times
#2399
Quoted: 157 Post(s)
Liked 17 Times
Very strange - to my knowledge, Centurion never used a French manufacturer. Have you checked the diameter of the stem and tubing to see if the dimensions are French?
#2400
Well.....................
I don't see any lugs. Looks like a butt welded steel frame to me. The chrome steel wheels with little dimples in the rim is a trademark of inexpensive bikes built in the late 70's early 80's.
The Simplex shifters & Weinmann brakes are way out place on a bike with a Centurion label. The Centurions from that era usually had SunTour or Shimano components on them.
I've bought, sold, traded and refurbished at least a dozen Centurion bikes over the last twenty years. Never seen nothing like this before. Just guessing. This bike must have been built for the European market & not sold in the US.
