Official Trek FX Thread
#2126
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Depending on how you ride and where you live, any 10-speed cassette will do as long as it's within range; i.e. 11t (or larger) to 46t (or smaller.) Check the specs for your particular drivetrain (Shimano Deore M4100 in your case) - there's a range that Shimano state on their website. Be careful, though: you might need to swap out your chain for a slightly longer or shorter one if the cassette change you're thinking of is on the extreme side.
#2127
Quoted: 763 Post(s)
Liked 1,731 Times
Shimano do not require that the smallest cog be 11t. Shimano have never been known to be great on wording. What you read on the website actually means is that 11t is the smallest possible high-gear cog that can be used with that drivetrain; anything larger than that would work just fine. You (or jaxgtr ) can build a custom 11-speed cassette with cogs in one-tooth increments and it'll work just fine - if you're so inclined, that is. But whereas that sort of thing might have been heroic in the 1980s, it would be called downright masochistic today
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
#2128
So after spending years trying to ride a 2002 Cannondale F400 mountain bike in a fitness role, I ended up buying a 2020 Trek FX3 a few years back. It's been a good bike, and honestly it just highlighted how uncomfortable that Cannondale was, even after I replaced the handlebars and stem and such over the years.
I put Race Face Ride pedals on it which is a wide platform pedal, but they're plastic and don't have metal spikes sticking out. They work great. I then replaced the saddle with an Ergon SFC3 and put the old one on the Cannondale. It wasn't that the Trek saddle was bad, it actually was pretty comfortable and I needed something better on the old bike as my son is now riding it but the Ergon is just a wee bit better so it's mine.
Anyway this year I've decided I want to do some improvements to the drivetrain. There are two niggly little things. First, I decided the 46 tooth front gear is ridiculously large and I never use it. Our trails tend to be long slow uphill climbs, hardly ever anything flat, and I have zero interest going super fast downhill, so I'm nearly always in the 30. So I decided to order a Deore M4100-2 crank with 36/26 chainrings. I'll probably have to shorten the chain and adjust the front deraillerur.
Now the other thing is I think the Alivio shifting on the 9 speed rear is sluggish. Although the front feels fine. So when it warms up a bit in the garage I'm going to go take a look at that. It's may just be binding at some point or needs lubricating. My Cannondale had a Deore XT that shifts like a dream and spoiled me. Then last year I bought a Marlin 7 Gen 2 to ride with my son on the off road trails, and that came with the 1x10, and it doesn't shift quite as snappy as that old XT, it's still better then the Alivio. Now, because I was ordering that crank, and a M5120 rear was only $35, I bought one of those too. If I can't easily see something wrong with the way the Alivio is running, I'll try swapping it out for the M5120. Now both the new crank and this derailleur are for a 10 speed, but from everything I've found they should still work with the 9 speed shifter, chain and cassette.
If not, I might just complete the upgrade and go 2x10. I don't think I'd like a 1x10 with a 11-46 rear like the new FX3. I did check, and I can get up to a 38T chainring for the 96BCD mounting of the M4100. So not quite the 40, but again I think I like having things geared a bit lower anyhow. But maybe a 2x10 with 11-34 or 11-32 would be good. Have to see how this goes.
#2129
Quoted: 1397 Post(s)
Liked 1,873 Times
Shimano MTB 9 speed and 10 speed shifter / derailleur pull might be slightly different - ? - can’t recall ... ???
#2130
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
Yes, MTB 9-speed and MTB 10-speed use different cable pull ratios. It would be best to stick with the same family (shifter, derailleur, cassette, chain) when upgrading the bike or changing components. There are sometimes parts from different speed groups that are compatible with each other, and there are usually ways to make incompatible parts work together, but the path of least resistance for sure is just using stuff from the same family or group.
#2131
#2132
Liked 761 Times
10 speed road, with the exception of Tiagra 4700 and GRX, is compatible with 6/7/8/9 speed mountain groups. But 10 speed mountain is not compatible.
Reference link
Reference link
Likes For hokiefyd:
#2133
Liked 1,873 Times
Reference link
Reference link
I have a Tiagra / GRX / Ultegra / XTR combo on one bike :
ST-4725 shifters - GRX 810 FD - R8000 RD - M980 11-34 cassette
#2134
Vegan on a bicycle
Greeting to all of the Trek FX experts!
I'm trying to build up a city/grocery/hill bike, and hit a snag with the Giant Cross City (aka Escape) 2 that I started with - https://www.bikeforums.net/bicycle-m...ront-rack.html
Now I'm considering using a Trek FX2 as the starting point. The bikes seem to have nearly identical geometry, and they seem designed for the same kinds of riding. Same plan as before, start with a cheap but solid used bike, strip it down to frame and fork, and rebuild it as I need it to be, including a 3x10 drive-train.
On paper, one of the things that concerns me about the FX2 is the published specs: "Max tire size - 38c without fenders". That's not bad, but I do have 700x42 (44-622) tires that I'd like to use for this project.
Any other things to consider?
- Wondering what the limiting factor is,
- and if a wider tire will work on the front,
- maybe I could find a used FX2 fork and use that with the Cross City frame
#2135
Bikes: 2015 Trek FX 7.0 - modified to be better on the road than it was designed to be. Now, 2021 Domane.
Quoted: 23 Post(s)
Liked 10 Times
Call me a Debbie Downer if you want but....
Unless you're doing this because of challenges of the ... work, effort in finding parts, and the costs involved are offset by the fun of the build, why don't you just go out and buy that bike you're looking for? Trek, for example, makes it seems, different models of bikes that ought to suit your goal.
#2136
Vegan on a bicycle
The big thing I'm looking for that's not fashionable on current off-the-shelf bikes is a 3x10 drive-train, with 40-30-22 crankset and 11-42 cassette. This gives me a gear ratio (from lowest gear to highest gear) of almost 700%, which lets me keep a comfortable cadence up and down hills, with or without panniers full of groceries. From a walking speed to +50kph, I can maintain a comfortable spinning cadence. Also, I like 170mm crank-arms, which I'm not going to find standard on any large-frame bikes.
https://www.gear-calculator.com/?GR=...N=KMH&DV=speed
If you can suggest an off-the-shelf, aluminium, city/grocery/hill bike that can do this, let me know. Otherwise, it seems like I have to start with a bike like the Giant Escape 2 or the Trek FX2, strip it down and build it up. The good news is that I kind of do enjoy doing the work. The cost is non-trivial, but if I start with a used bike it's reasonable.
#2137
Quoted: 23 Post(s)
Liked 10 Times
They aren't common, but....
If it were that easy...
https://www.occyclery.com/products/c...ls-size-medium
Then, the used market.....
https://99spokes.com/bikes/bianchi/2...-slxdeore-3x10
and elsewhere. Of course, none of that might work because some of these sources are.... aren't in the country where you are. I'm a big fan of having a rear cassette with enough gears with one tooth spacing allowing me to keep cadence in a narrow range. For me, that works with a 2x10 trannie. 3x10 is more than I think I'd ever need, but then to each their... of course. Good luck!!
#2138
Vegan on a bicycle
Found one, here:
If I lived on the flats, or if I didn't use my bike for grocery shopping, I could enjoy a bike with more common gearing. I blame e-bikes. Terrain that used to demand triple cranksets is now getting people onto e-bikes, so now 3x is just out of fashion, and wide-range cassettes are even pushing 2x out of fashion.
Anyway, the Giant Escape 2 seemed like a good "platform" for building up a city/grocery/hill bike the way I want/need it. Now I'm looking into the Trek FX2... Or maybe use the fork from an FX2 with the Giant Escape 2?
#2139
Has anyone figured out a way to use a burley child trailer mount on the new FX Sport skewer/dropout? Trek says its not possible but my dealer is trying to come up with a solution...
#2140
Liked 761 Times
It seems like a near-new MTB would be a good choice for you, smasha. You can replace the fork with a suspension corrected fork or similar, from the likes of Surly or Salsa. One of the bikes I ride most often is exactly this...an alloy MTB with a Surly fork. I think I have about $500 total into the bike, but it was very fun to build and configure just how I want it.
It has a rigid fork, MTB fenders to cover 27.5x2.25" Conti Ride Tour tires, hydro disc brakes, and a 3x9 drivetrain (but could easily be 3x10 if I wanted that.
Not to take away from an FX, but you might consider a used Marlin or Talon or similar.
#2141
Vegan on a bicycle
In terms of specific bikes that are locally available and meet these criteria, I really haven't found anything other than the FX2.
#2142
Liked 761 Times
My requirements for a fork are: Front rack compatible, aluminium, non-suspension, 700c, and overall suited for touring/grocery. Of course it has to be something I can find locally, which further limits my options.
#2143
Liked 761 Times
I don't think the fork will limit your tire clearance on an FX. The limiting factor is probably clearance down at the chain stay or bridge area.
Another bike to consider is the Trek Verve 2 or 3, if it's available in your area. It comes from the factory with 700x45 tires, has an alloy frame and fork, and appears like it meets most or all of your criteria, without you needing to swap major components. The drivetrain is not 3x10 out of the box, but this is no different than you'll find with an Escape or FX, either.
#2144
Vegan on a bicycle
For longer rides, I've got a flat-bar upright-posture touring bike that's well equipped for groceries (yes, I'll sometimes ride 25-30km with 400m of elevation gain, each way, for a grocery shop). That's my "cruiser". The Escape and the FX seem better suited for more agile/aggressive city riding, which is what I'm currently after.
#2145
Vegan on a bicycle
All I need now is an FX2 fork.
The geometries, including head-tube length, are nearly identical between the large Cross City/ Escape and the large FX2. I'm not sure if that means I'd need a large (or larger?) FX2 fork? Or any FX2 fork should work?
#2146
Liked 761 Times
I think all sized FX 2 forks are the same, save for the practice of cutting the steer tube to correlate with the head tube length. If you're looking to source an FX 2 fork, it'd be great if you could get an uncut fork. I don't think you can generally get these as "service parts" from a Trek dealer, but it might be worth asking.
Likes For hokiefyd:
#2147
Vegan on a bicycle
The large FX2 head-tube and the large Escape head-tube are both 160mm, ±30mm for medium and XL. Assuming the steerer-tubes are cut proportionally to the head-tubes, yeah, a fork from a LG, XL, or XXL FX2 should be fine for the large Escape... I think. But again, if I get my hands on a large FX2, that may be my next city/grocery/hill bike.
#2148
Vegan on a bicycle
Maybe my next bike will be an FX2? Maybe I'll take that fork and make a Frankenbike with the Cross City 2 frame, and sell/donate a Frankenbike with an FX2 frame and Cross City fork?
Likes For smasha:
#2149
Vegan on a bicycle
Still keeping a lookout for a used FX2...
Was 2019/2020 when the cable routing along the down-tube changed from external to internal?
Any changes to the fork, before, during, or after that period?
#2150
Liked 1,873 Times
