isis to square taper adapter.
Bike Honky
Bikes: KHS touring thing that's old, French? fixxie, 69 schwinn stingray show bike.
anyone make something like it. i'm imagining an insert for the cranks.
Likes For sydney:
如果你能讀了這個你講中文
Bikes: Peugeot Hybrid, Minelli Hybrid
Originally Posted by genericbikedude
or invent an internally geared bottom bracket that works for fixed gear.
Likes For AndrewP:
Likes For Raiyn:
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
while your at it, please invent and market an internally geared fixed hub that switches between freewheeling and fixed.
- Take one freehub.
- Place under high-pressure wash.
- Hang to dry for one week.
- Lace and mount hub to wheel.
Where's my check?
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Quoted: 19 Post(s)
Liked 7 Times
3-speed internal-gear, fixed-wheel hub:
https://www.sheldonbrown.com/asc.html
Bike Honky
i want to use isis drive cranks on my french threaded frame. don't treat me like a jackass.
如果你能讀了這個你講中文
Originally Posted by AndrewP
Isnt that a Schlumpf?
Quoted: 114 Post(s)
Liked 119 Times
Back to the original question... You might want to check out: https://www.thethirdhand.com/. If anybody sells or knows of such an adapter, it'd be these guys. The guys offer some pretty esoteric parts. They're located in your neck of the woods - Ashland, OR.
Bike Honky
yeah, here's the thing. I am very broke at the moment. i cant afford a phil bb and nice new campy cranks. i can however stare at the brand new truvative cranks that i got kicked down. just looking for a temporary fix.
No one carries the DogBoy
can you use the truvative cranks that take a square taper?
https://www.sram.com/en/truvativ/road...uro/double.php
Originally Posted by khuon
- Take one freehub.
Where's my check?
DEADBEEF
Liked 6 Times
Originally Posted by DogBoy
what happens when you want to go back to freewheeling?
Champ
seriously, though. I think you're hosed.
I know Phil makes French 'cups', and I've heard you can put a UN72 between them. They might even fit the important part of your ISIS.
Then again, they might not.
This is do-able, but not in the way that you imagined it. You need a cartridge ISIS BB where you can remove both cups (just about anything from China should come apart in this way). Now, purchase retaining rings for a cartridge bottom bracket from Phil Wood of San Jose, CA. That way, you can mount your ISIS bottom bracket in a french-threaded frame. Problem solved!
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Zombie Thread Alert!
Likes For JanMM:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 4201 Post(s)
Liked 3,857 Times
Three holy grails of bikedom- A universally comfortable saddle that weighs what it needs to, chain lube that won't wash off or get grimy, and an air filled tire that can't go flat and still rides well. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
