6 speed derailer works for 7 speed or no?
6 speed derailleur works for 7 speed or no?
Hello i am confused RD-TZ500-GS listed as 6 speed, but on website say 7 speed also okay?
Will this derailleur work on 7 speed cog?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
do you know what the high and low limit adjuster screws on a derailleur are and do?
In my understanding 6 speed derailleur body has less travel than 7 speed so screws might not do the trick.
besides marketing why they even making different derailleur version 6, 6/7, 7/8 speed they might as well just make one 8 speed derailleur just limit movement with screws this would remove all the compatibility issues.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Yeah i know what limiter screws doing.
Browse through https://si.shimano.com/ for the compatibility charts and you’ll find this.
Clip from 6s and 7s rear drivetrain compatibility
As can be seen, most of the rear derailleur for 7s can be used for 6s. A tiny number can only be used on 6s. If you navigate there, you’ll find some can even be used on 8s. The boundary isn’t a wall.
Likes For dwsmartins:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
that tourney derailleur will handle up to 7spds without a doubt. i have a tourney derailleur that's the predecessor model to the one you're looking at. it came with the bike to shift a 7spd freewheel. but, i've seen them on other bikes before with 6spd freewheels. i don't know what you're financial restraints are, so in the interest of going budget there's the model you're looking at going for $17 on ebay right now. that's pretty cheap, man. and, hopefully it performs better than the one i have. it does looks like a better design and gets 4 out of 5 ratings on amazon
Unless I missed it, isn’t the real point of this question to ensure that your shifter matches your rear cassette?
No matter how much you finesse it a six speed shifter will (almost) never work perfectly on a seven speed rear gear set. Nor will a seven speed shifter work perfectly on a six speed cassette/freewheel.
Yes all derailers have limits for their range but that range usually relates to the largest gear sizing. So first and foremost, are you using a seven speed shifter with a seven speed gear?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
The Tourney stuff was developed by Shimano as a 7-speed groupset. It is now being cross marketed into the 6-speed slot to broaden its usefulness and market. It's backward compatible for sure. The real question, if the OP is indexing (maybe not), is whether the shifters are compatible with the derailleur and the rear cog spacing.
Quoted: 514 Post(s)
Liked 448 Times
